Thread: Boring Cylinders
Results 1 to 20 of 23
  1. #1 Boring Cylinders
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    lol sounds like they are boring...
    but i mean to bore a cylinder in this car, would it be possible to make it big enough that you go from a displacement of 3.8L to 4.5L?
  2. #2 Re: Boring Cylinders
    new britain, ct
    i dont think you can do that big of a displacement change.
    however, i do see people bore out their old grand national blocks (3.8) to a 4.1L. i dont see too many amazing results from that though.
    07 Black GXP.
  3. #3 Re: Boring Cylinders
    Florida
    to a 4.5L? How any why did you come up with that number?
    On stock stroke, no way. The biggest would be with a stroker kit, and bored over, getting you to 4.2L. It'd be awesome, but expensive as hell.
  4. #4 Re: Boring Cylinders
    The stock bottom end is fine and boring out the cylinders does not give enough of a performance increase to justify the cost. /end thread
  5. #5 Re: Boring Cylinders
    Mar 2012
    Minneapolis MN
    hmmm. it makes me curious because i had 4.5L written on both my cylinder head covers... i havent taken them off yet to see due to other car problems and me being busy.
  6. #6 Re: Boring Cylinders
    LOL, that's funny.
    4.5 liters is ricer math.
    Swan Racing makes a 4.25 liter stroker kit for the 3.8, ala...quite a few G's.
    Swan Racing 3800 Stroked Engines
  7. #7 Re: Boring Cylinders
    Mar 2012
    Minneapolis MN
    well like i have mentioned previous, i had a pretty sloppy engine swap and previous owner lol
  8. #8 Re: Boring Cylinders
    If the previous owner was sloppy...I'm sure he didn't buy a made up 4.5 liter stroker kit.
  9. #9 Re: Boring Cylinders
    Mar 2012
    Minneapolis MN
    So he just wrote on it for Sh!ts and giggles? lol
  10. #10 Re: Boring Cylinders
    Sure.
    I'll draw a Zebra on the next 3800 I work on.
  11. #11 Re: Boring Cylinders
    Mar 2012
    Minneapolis MN
    do you think maybe he was an idiot and wrote on it so he knew how much oil to put in?!
    since it takes 4.5 quarts
  12. #12 Re: Boring Cylinders
    mi
    Looking to run some 2.250/1.800 valves or what?
  13. #13 Re: Boring Cylinders
    Mar 2012
    Minnesota
    Thatd be some huge a$$ pistons and some long a$$ rods. Id guess the engine would make it about 1320 ft... maybe lol. Nahh the cylinders wouldnt have enough material between them and your pistons would have to be very shallow. Id bet it was just the oil number or if it was swapped it could have been swapped in april of 05 lol
    Mar 2012
    Minneapolis MN
    It wouldn't have been swapping date, cause it was swapped in 07.
    I'm assuming he was just an idiot and thought liters were quarts
  15. #15 Re: Boring Cylinders
    30 thou and the block is done.
    Pistons are already very close to one another anyways.
  16. #16 Re: Boring Cylinders
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    oh my... a .7l jump is quite impossible on this block lol, or i think most blocks... for that amount of money, why not just upgrade the crap out of everything else to get power??
  17. #17 Re: Boring Cylinders
    Florida
    ^ You can bore a SBC 350 .060 over and put in a 400 crank and have a 414CI engine. 350=5.7L 414=6.8L So you grab 1.1 liters right there. And that's only a small block, some even push the bore .080 over, but then the cyl walls are too thin to handle as much power.
  18. #18 Re: Boring Cylinders
    I'd bet it was oil. 4.5 liters is 4.75 quarts. Perfectly within the limitation of what we can dump in w/o worrying.
  19. #19 Re: Boring Cylinders
    May 2012
    pensalvania
    that sounds very expensive lol
  20. #20 Re: Boring Cylinders
    Minnesota
  1. Who knows how to see in the cylinders?
    By Gasnmyveins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2011, 08:40 AM
  2. Misfire in all cylinders except #1
    By talontedGTP in forum General Tech Discussion
    Last Post: 06-21-2011, 09:54 AM
  3. What Do 8 Cylinders...
    By blueguy in forum Track Sessions and Kills
    Last Post: 12-20-2008, 01:55 AM
  4. coolant in cylinders
    By rharper33 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2008, 08:25 PM
  5. HELP!! My GP is Only Running On 5 Cylinders!!
    By y1a3o in forum General Tech Discussion
    Last Post: 05-14-2008, 11:20 PM
