Thread: N* throttle body.
Results 1 to 6 of 6
  1. #1 N* throttle body.
    GT Level Member Erics00LS's Avatar
    Lindenhurst, IL
    What's needed to make it work on my l36? Have one at my disposal..
    '03 Buick Park Avenue Ultra - a few bolt ons
    http://www.facebook.com/groups/greatlakesareacarenthusiasts
  2. #2 Re: N* throttle body.
    GTP Level Member buickman104's Avatar
    NYC
    Acquiring the throttlebody is the easy part. Now you need sensor pig tail adapters, lq4 Maf, tune for lq4 maf tables, and adapter plate. You might also want an aluminum upper intake to port so you can get more air in.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
    Uh ported lim and hv3 would be better than an l26 uim which has almost no benefit other than not being prone to warping.
    Also N* is too large unless youre using boost.
    Lindenhurst, IL
    so would it hurt performance on the l36?
  5. #5 Re: N* throttle body.
    How much air do you expect your engine to flow?
    If its less than 550 CFM, then an L67 TB is just fine.
  6. #6 Re: N* throttle body.
    If anything, port that LIM I sent you
    Then, HV3...ported L67 TB...re-tune on a WB.
    After that...flow mods and another re-tune?
    Timing out the wazzzoooooo
  1. Throttle Body? MAF? What is what?
    By davidinark in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-16-2011, 10:15 AM
  2. Throttle body in an 08
    By zenman400 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 09:01 AM
