Thread: Display/ lighter out?
Results 1 to 3 of 3
  1. #1 Display/ lighter out?
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    Hello all, my cd player display and ciggaerette lighter won't work. I can't figure it out. I checked the fuses, but I'm not getting anywhere.. Thanks.
  2. #2 Re: Display/ lighter out?
    St. Louis
    Does the CD player still physically work, just no display? If so then the bulb that backlights the LED display is shot. Common issue. GM has the bulb. If you can't find the part # I can look it up as I've replaced the one in mine before. Maybe pull the cig lighter out and check the leads for power if the fuse checks out good. Might just be a bad socket.
  3. #3 Re: Display/ lighter out?
    May 2012
    pensalvania
    yea, the cd player works. i thought the two were related. and the cig lighter socket is getting no power at all. will check the rest with a tester 2morrow.
  1. Removing Cigarette Lighter
    By matthew911 in forum Visual/Body Modifications
    Last Post: 12-15-2011, 11:19 PM
  2. Cigarette Lighter Fuse
    By matthew911 in forum General Tech Discussion
    Last Post: 04-06-2010, 10:35 PM
  3. Cigerette Lighter Not working
    By student in forum General Tech Discussion
    Last Post: 03-09-2010, 07:45 PM
  4. Cigarette Lighter Problems
    By missyfisch in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2009, 09:39 AM
  5. cig lighter
    By MizzBecca in forum General Tech Discussion
    Last Post: 07-12-2009, 11:08 PM
