Thread: Engine light on! Help me out!
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21
    Jun 2012
    Mississippi
    No I did not check the fuses. Is there a certain one I'm looking for? I just had the code read again its still throwing the same code. I'm puzzled the guy at the auto parts store said something about a sensor my have came unpluged he said I should crawl under the car and check that first. I'm assuming the plug he was talking about goes to my evap can.
  2. #22 Re: Engine light on! Help me out!
    SE Level Member 99XC600's Avatar
    Apr 2012
    Wilbraham MA
    Quote Originally Posted by Vinson clark View Post
    I believe it's #21. But I would check them all while you're in there
    2004 Ivory White Pontiac Grand Prix GT1 - Bone Stock and my 80 mile daily driver.
    Jun 2012
    Mississippi
    Checked all my fuses they are good #21 is good also. Filled up with gas this morning and almost didn't get the car to crank. It started on the 5th time. It only has trouble cranking after I fill up with gas any other time it starts fine. Engine light is still on as well. Looks like I'm going to have to take it to the shop Friday.
  4. #24 Re: Engine light on! Help me out!
    Apr 2009
    Fort Worth TX
    The problem may be the purge solenoid valve or the Pressure transducer.
    Jun 2012
    Mississippi
    I'm not real sure what it is man I gotta keep this car running though, and the not cranking after every fill up is really bothering me.
  6. #26 Re: Engine light on! Help me out!
    Apr 2013
    Ontario, Canada
    I'm having the exact same problem with my 2004 grand prix 3.8L N/A with engine code p0496 and I read on another thread that "The problem was that evap solenoid valve was stuck open located in the intake manifold." Still haven't been able to find what exactly this guy is talking about.. I've been looking for diagrams or pictures or anything along the lines and all I can find is the evap canister located inbehind the rear drivers side wheel. Maybe I'll have to take apart the whole intake. OH and as for the car not cranking after every fill I have this problem as well, and cleaned the throttle body up as best I could but it still does it, I think this problem could also have to do with evap solenoid valve in the intake...
  1. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
