Thread: put 5w-30 in 10w-30
Results 1 to 16 of 16
  1. #1 put 5w-30 in 10w-30
    Donating Users kind153's Avatar
    Pittsburg, KS
    1998 gt.
    got an oil change today...as i was leaving i notice they put 5w 30 instead of 10w 30. I drove 3 miles..should I be worried?
  2. #2 Re: put 5w-30 in 10w-30
    Grand Rapids, MI
    Nope. Read your manual. Either will work, depending on temperatures where you live...one can be better or the other.
  3. #3 Re: put 5w-30 in 10w-30
    Pittsburg, KS
    checked my manual..am i misled by the chart to think i'd be better with 10w-30?
    I'm in KS and the weather in summer here has been like 45~94F.
    put 5w-30 in 10w-30 Attached Images
  4. #4 Re: put 5w-30 in 10w-30
    Donating User Odi's Avatar
    Chicago South Suburbs
    ur fine. i drove on 5w-30 last summer without issues.
  5. #5 Re: put 5w-30 in 10w-30
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    gotta be a jiffy lube/lube pros. would never go there again if i were you
  6. #6 Re: put 5w-30 in 10w-30
    Pittsburg, KS
    so if doesn't matter, should i go 10w30 next time?
  7. #7 Re: put 5w-30 in 10w-30
    Nov 2010
    Illinois
    yes you should. its kind of like if you're always synthetic and someone puts in coventional. you're ok for a little while but make sure u put in synthetic next time lol
  8. #8 Re: put 5w-30 in 10w-30
    Grand Rapids, MI
    The important thing is you have oil. I always run 10w-30.
    And actually you can read some more if you're curious about oil types and such. http://www.bobistheoilguy.com/motor-oil-101/
  9. #9 Re: put 5w-30 in 10w-30
    Quote Originally Posted by bps02gtp View Post
    dont put synthetic if you got a high milage car.
  10. #10 Re: put 5w-30 in 10w-30
    Texas
    When I was supercharged I ran 10w-30 in the summer and 5w-30 in winter. You will be fine
    85 Corvette
    01 TA
    03 Z06
    Again why?
    If its been well taken care of then it wont matter.
    Take filler off and look at rockers.
  13. #13 Re: put 5w-30 in 10w-30
    GT Level Member TeeWX's Avatar
    Apr 2009
    Cresco, Iowa
    You can't change your own oil?
    1998 GTP : XP Cam, 3.2 Pulley, Supporting Mods<Sold>
    2001 Formula M6 : Shhhh
    2001 SSEi : New DD, Bone Stock for now
  14. #14 Re: put 5w-30 in 10w-30
    Jan 2012
    Austin,tx
    Thats not true you can switch and your motor will never know the differance. Like running a syn. blend which is a mixture of both oils. To the OP the only differance between 5w-30 and 10w-30 is that 5w-30 will flow better in below 0 temps. during a cold start up. After both oils are up to temp they are the same.
    06 Grand Prix GT stock, 02 Mustang GT far from stock
  15. #15 Re: put 5w-30 in 10w-30
    Pittsburg, KS
    ok..didn't mean to start any debate..but thanks for all inputs.
    and no, not having a garage and summer temp doesn't make it look so fun to me;
    Quote Originally Posted by DreamerGT View Post
    You sir win.
