Thread: How to change fuel filter in 2000 model
Results 1 to 20 of 22
  1. #1 How to change fuel filter in 2000 model
    Mar 2012
    Decatur GA
    Can someone explain to me how to change the fuel filter for 00 model grand prix? All help is very much appreciated thanks!!
  2. #2 Re: How to change fuel filter in 2000 model
    Take off the quick connect side and put a line wrench on the line and use a big pair of channel locks and spin the fuel filter off.
  3. #3 Re: How to change fuel filter in 2000 model
    Florida
    It's very simple, release the quick disconnect (squeeze and pull) and then wrench the nut off.
    Usually they are rusted pretty badly, so you might need to get some PB Blaster and a heat source (please dont use a torch, fuel + fire = bad) and soak the nut until it will break free.
  4. #4 Re: How to change fuel filter in 2000 model
    I live here. TLSheff's Avatar
    #8 Fuel Filter - GM# 25121293 / ACDelco #GF578
    Middle of the car on the driver side, need to jack up and support properly before you get under.
    Quick connect on one side, bolt on the other side. Need to unbolt the bracket that holds the filter to get it loose enough to slide the old one out and the new one in, or unbolt completely and put back onto new one prior to installation.
    Warning, keep face out from underneath it unless you like the flavor of gas, you will spill some during this process.
    Also - DO NOT SMOKE WHILE CHANGING THE FILTER!!!!
    All in all it should only take a few minutes to change one the car is supported. Its easy, just unbolt one side with 2 wrenches, once its loose, use your fingers or pliers to push the tabs in on the quick connect side and remove. reverse to install new one.
  5. #5 Re: How to change fuel filter in 2000 model
    Mar 2012
    Decatur GA
    My car loses power when going uphill. it also tends to misfire sometimes especially when i floor it. i often get rough idles as well. Does this sound like fuel filter???
  6. #6 Re: How to change fuel filter in 2000 model
    Florida
    One of a few possibilities. Could be plugs n wires, bad coils, vacumm leak,clogged cat, one of the TB sensors could be dirty or bad. But start with fuel filter, its cheapest.
  7. #7 Re: How to change fuel filter in 2000 model
    Florida
    Could very easily be a very clogged filter. Start there, if that doesn't fix it then:
    Check your plug wires, make sure they dont have any frays, cuts, tears, or rust on the inside of the boots.
    Check your plugs. Check for cracks in the porcelain, and see if they are properly gapped, and not fouled.
    Check your coil packs for rust on the terminals, or any cracks/splits in the coils themselves.
    If it feels like your hitting a wall during acceleration (doesnt want to go over 4000rpm or so) then it's most likely the catalytic converter.
    If you're still lost, get the OBDII codes pulled, and see which cylinders it is misfiring on, and go from there. If it comes back as a "Multiple Cyl. Misfire" it more than likely a bad coil pack.
  8. #8 Re: How to change fuel filter in 2000 model
    ^ This
    Start with the fuel filter.
    If it still drives funny, I would suggest going to a local parts store and buying "MAF Cleaner Spray". You will want to use it to spray the MAF and make sure its clean and not dirty and causing a bad signal... never touch the sensor, just spray it and let it dry.
    Second would be to get some Injector cleaner spray and spray the connector points on the vacuum lines, doing this will let you know if there is a leak. If there is a leak (spray each connecter while engine is idling) when you spray that point it will cause the engine to surge up and the rpms will rise. Go slow, so you know exactly which point has a leak.
    Change plugs and wires with good quality parts, most use Autolight 606s and w/e wires have a life-time warranty for stock use. Or buy AcDelco replacements
    Plugs GM# 12568387 (ACDelco #41-101) (IRIDIUM)
    Wires GM# 19171849 (ACDelco #726RR)
    Make sure if you replace the wires, you clean the contacts on the coils, and you replace wire for wire 1 at a time so you don't wire them up wrong. That would just cause more problems lol.
    Good luck, let us know how things go.
  9. #9 Re: How to change fuel filter in 2000 model
    michigan
    I was gonna do my ff, then chickened out when i seen how rusted the lines were. Thought if id try and break the nut free id possibly snap the line, then id have a whole nother project on my hands, and prob a pricey one too. Lol
  10. #10 Re: How to change fuel filter in 2000 model
    Florida
    Thanks for repeating what i said machinegun but in detailed fashion. My line was rusted to the nut so after nearly 30min of me strugglin i asked my handyman neighbor and he got it undone in like 5 min. It can be broken free just gotta keep at it or use PB blaster.
  11. #11 Re: How to change fuel filter in 2000 model
    Or don't worry about breaking the nut free and just spin the filter
  12. #12 Re: How to change fuel filter in 2000 model
    Mar 2012
    Decatur GA
    @machingunsquid i tried to rev the car while in park and it did seem to hit a wall at about 4000 rpm or so. My acceleration is not too bad tho. I am thinking i could possibly have a bad cat converter but would that make my car rough idle and turn off at red lights as well???
  13. #13 Re: How to change fuel filter in 2000 model
    You have a rev limiter when in park so you dont over rev the engine. That's normal
  14. #14 Re: How to change fuel filter in 2000 model
    Mar 2012
    Decatur GA
    @dsmuts thanks..i did not know that. So in that case i take it my cat converter is good.
  15. #15 Re: How to change fuel filter in 2000 model
    To know for sure you really need to put a load on the engine, DSMUTS is right, under 15mph the computer will keep the engine from going over a certain RPM to keep you from endangering the motor. Get out on a safe area/highway on-ramp and WOT (Wide Open Throttle) to the speed limit (we don't condone speeding/careless driving ) If this is when it is cutting out you have a problem. If it cuts out at higher RPMS it could be fuel or spark related, if it starts chugging and wont even get to higher RPMS when you floor it, then most likely a clogged converter.
  16. #16 Re: How to change fuel filter in 2000 model
    Mar 2012
    Decatur GA
    It does not have a problem getting up to high speeds. My main problem is the rough idle and the car turning off at red lights. Sometimes i have some misfire. these are the things that concern me the most that i would like to fix. This is why i am thinking i need a fuel filter. I just need to be pointed in the right direction so i can purchase the correct parts and get this baby fixed!
  17. #17 Re: How to change fuel filter in 2000 model
    Florida
    In that case, it's probably not the cat, during acceleration you will feel the car bog, and feel starved for power.
    Change the fuel filter, it's cheap, and is a good preventative maintenance.
    New spark plugs and plug wires, again, cheap and easy to fix, and good preventative maintenance.
    Do those, and I bet you'll be golden.
  18. #18 Re: How to change fuel filter in 2000 model
    Mar 2012
    Decatur GA
    New info. Today i noticed some hissing from under the hood... sounds like it is coming from the front on the driver side.... any ideas what this may be?
  19. #19 Re: How to change fuel filter in 2000 model
    Vacuum leak
  20. #20 Re: How to change fuel filter in 2000 model
    Mar 2012
    Decatur GA
    sound like it is coming from somewhere close to the MAP sensor
  1. sluggish / misses / dies / did tune up w fuel injection / did fuel filter / car runs
    By dlc723e in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-30-2012, 08:25 PM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Changed Tranny Fluid/Filter, Fuel Filter Tonight
    By nickbuol in forum General Tech Discussion
    Last Post: 10-15-2010, 06:04 PM
  4. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
