Thread: 08 idles and runs bad
Results 1 to 15 of 15
  1. #1 08 idles and runs bad
    Mar 2012
    Grand Rapids
    So Im slowing down for a stop light and all of a sudden the car starts shaking, and when we stop its sounds like its missing pretty bad. Ran the codes and it came up with the p0300 random misfire. It lists so many potential causes im looking for help. A couple months ago i had to replace an ignition coil and the icm.
  2. #2 Re: 08 idles and runs bad
    I'd start with replacing all spark plugs with new AC delco's, then cleaning the MAF sensor and Throttle body.
  3. #3 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    There is no throttle body its injected, sorry.
  4. #4 Re: 08 idles and runs bad
    you most certainly do have a TB, and they get dirty and make the car run poorly. its at the end on the tube from the air box where the air filter is.
    it has a butterfly flap like a carb, behind it is where its dirty.
  5. #5 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    Ok, but would these problems cause it to start missing just that quick?
  6. #6 Re: 08 idles and runs bad
    the misfire is most likely your plugs are shot, and the wires, you have the icm and coils replaced already.
    a dirty TB will just make it run rough and a rough idle and stalling, hard starts.
    when i bought my car i had a po300, plugs and wires fixed that.
  7. #7 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    Ok, ill try the cleaning and plugs and wires, thank you and ill post again asap.
  8. #8 Re: 08 idles and runs bad
    dont clean them, replace them, you can get copper plugs for 2 bucks each, wires for 30, good old stock replacement is all you need.
  9. #9 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    That's what i meant, replace the plugs and wires and clean the maf and throttle body.
  10. #10 Re: 08 idles and runs bad
    Dec 2011
    Philadelphia, PA
    does the car shake when it ALMOST comes to a complete stop every time u stop or just sometimes?
    AEM bruteforce intake
    Diablo 93 Octane tune
  11. #11 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    Its just missing bad, it gets worse as the car warms up. I forgot to mention that i have put injector cleaner in it already.
  12. #12 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    Its missing bad, its rough at idle but havnt taken it at highway speeds, it still runs pretty rough around town. it seems to get worse as it warms up.
  13. #13 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    Hello again, I was testing the ignition control module. Is every male spade terminal (6) on the module supposed to be getting 12v when the key is turned on? Or is just one of them supposed to be getting 12v per ignition coil?
  14. #14 Re: 08 idles and runs bad
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    yes. and ive seen misfires on many different cars. and it is almost always plugs/wires. sometimes it can be fuel injector. but i highly doubt that on an 08.
  15. #15 Re: 08 idles and runs bad
    Mar 2012
    Grand Rapids
    Got the car fixed today. It ended up being the ignition control module. I replaced it and a coil just 3 months ago. I wouldn't have expected it to be a new part i just replaced. Thanks for the help to all of you. Until next time...lol.
  1. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  2. what are all the reasons why my car IDLES high ?
    By turboLude in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-31-2012, 04:32 PM
  3. at start up car idles like its cammed but isnt????? more info inside
    By dboy187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2012, 01:27 PM
  4. Idles for 5 seconds then dies
    By 00grandprix in forum Engine
    Last Post: 04-30-2011, 04:32 PM
  5. car idles shakes
    By handymontana in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2010, 01:45 PM
