Thread: car wont start
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 119
  1. #1 car wont start
    GT Level Member bmx6454's Avatar
    May 2012
    pensalvania
    my 98 gp n/s wont start after doing alot of work to it. it has fuel and spark, and battery is good. and the intake gets warm to the touch after cranking it. and it sounds like it hesitates a little sometimes when cranking it. thanks
  2. #2 Re: car wont start
    plugs wires on wrong?
  3. #3 Re: car wont start
    May 2012
    pensalvania
    i dont think so. the backs are: 1-3-5, and the fronts are: 2-4-6, right?
  4. #4 Re: car wont start
    nope.
    left bank (front) is 1,3,5
  5. #5 Re: car wont start
  6. #6 Re: car wont start
    May 2012
    pensalvania
    oh ****. my bad lol, im gonna go switch em' up, and cross my fingers. thanks.
  7. #7 Re: car wont start
    May 2012
    pensalvania
    well, the battery is dead, and autozone is closed, so i guess ill have to wait till the morning to see. but my neighbor heard my cranking it(whom was a mechanic of 20 years), and he said he thinks its my timing chain, possibly slack from a bad/worn tensioner. but the motor doesnt really sound any different from my buds 3.8. any thoughts on this?
  8. #8 Re: car wont start
    whats all the work you just did?
    popping from the intake is almost always a ignition problem like plug crossed wires.
    or bent push rod, less likely, but dont know what you did to the car.
  9. #9 Re: car wont start
    May 2012
    pensalvania
    well, my friend owned it for a while, and the head gaskets and uim, and lim gaskets all went seemingly at the same time. so i took it off his hands for a very good price. i replaced head gaskets, head bolts, lim gaskets, uim+gaskets, spark plugs, wires, flushed the coolant, and oil. there is only one notable thing, and that is when i was taking the engine apart, clumsy me forgot to disconnect the battery, and i touched the alt. positive wire, and the block together with a screw driver, and it shot a few sparks. but i checked all the fuses and relays, and a car would start with no alt as long as the battery was good i think.
  10. #10 Re: car wont start
    May 2012
    pensalvania
    push rods all lined up nicely, and are in the exact order that the came out, and popping? what would this sound like? cause there was a strange noise occasionally when cranking that sounded like very faint fire crackers. i thought it might have been small backfires. and the uim was the only part that got warm to the touch. not even the exaust manifold got warm.
  11. #11 Re: car wont start
    jumper cables
  12. #12 Re: car wont start
    it was warm becuse if the wires were on wrong it would backfire through the intake.
  13. #13 Re: car wont start
    May 2012
    pensalvania
    jumper cables would work.. if my car wasn't on jacks in my backyard lol.
  14. #14 Re: car wont start
    check your wires one more time.
    and take the battery out, and hook jumper cables up to it for 30 minutes, it will charge it enough.
  15. #15 Re: car wont start
    May 2012
    pensalvania
    i did check the wires, they r now correct, but unfortunately its gona have to wait till the morning for a couple reasons, mostly rain..
  16. #16 Re: car wont start
    im in jersey, i feel your pain. im just starting to hear some thunder, and see some lighting flashes.
  17. #17 Re: car wont start
    May 2012
    pensalvania
    i actually live right next to jersey. got friends and family scattered all over jersey. but im hoping this rain lets off in the morning.
  18. #18 Re: car wont start
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    I have the same problem change the lim gasket on my supercharged engine and now don't want to start it backfires thru the intake I already check the wires and they are correct any other suggestions?
  19. #19 Re: car wont start
    Jan 2012
    Philadelphia
    BMX6454 you spelled Pennsylvania wrong in your location lol where at in PA are you from im right next to NJ too
  20. #20 Re: car wont start
    May 2012
    pensalvania
    i was never good at spelling Pennsylvanian haha. i live in easton. edit: tried the car, no start.. backfires out of the exaust now instead. it almost started once, after using a little starting fluid very sparingly. i tried unplugging some sensors and stuff, but no dice... and the exaust smells like gasoline, and the oil had some combustion gases in it. any advice?
  1. Help help gtp wont start
    By GTPWINDYCITYBOI85 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2012, 10:12 PM
  2. wont start
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 01:56 AM
  3. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  4. car wont start
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 05:56 PM
  5. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
