Thread: Coolant leak!! :(
Results 1 to 14 of 14
  1. #1 Coolant leak!! :(
    Mar 2012
    Altoona
    the part that is leaking is a coolant bypass elbow and the Tensioner Assembly will need removed to replace it. There are two elbows that connect it to the engine and both elbows should be replaced at the same time.. But where can I find these elbows? I searched ebay and amazon but found no results
    Its a 1998 by the way.
  2. #2 Re: Coolant leak!! :(
    parts store.
    6,000th post, woot.
  3. #3 Re: Coolant leak!! :(
    On a 98 you only have one replaceable coolant elbow. Autozone has them in the help section.
  4. #4 Re: Coolant leak!! :(
    Nov 2010
    WI
    Sorry to jack your thread but I have the same issue ever since I replaced my LIM gaskets and UIM. I have a 2002 so I have 2 plastic elbows. I replaced both elbows with new when I did the intake however they began leaking almost immediately. It looked like the new orings wore out right away. I then removed both elbows and sealed them up with high temp RTV but it is leaking again. I got my new elbows with my new Dorman upper intake. Does anyone have any suggestions to fix this issue?
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    During my LIM job i replaced these elbows and they never leaked. i put a sizeable bead of RTV in front of the orings so the RTV would seal around them. Make sure you removed ALL of the old plastic elbow pieces, both of mine left broken pieces in there.
    You can find these elbows at most auto parts stores in what they call the HELP section. good luck.
  6. #6 Re: Coolant leak!! :(
    I just shoved mine in and they haven't leaked a drop.
  7. #7 Re: Coolant leak!! :(
    SE Level Member 99FormulaM6r's Avatar
    May 2012
    Quote Originally Posted by jakegsxr11 View Post
    Quote Originally Posted by KZOO3800 View Post
    Exactly, odds are you still have a piece of the elbow inside of the block or tensioner.
    1999 Pontiac Firebird Formula M6: SLP lid, LS6 intake, GMMG catback, MGW, blanks/HPS/SS lines, Koni 4/4, Strano 35/22 sway bars, UMI PHB
    2001 Pontiac Grand Prix GT
    2007 Yamaha TW200
  8. #8 Re: Coolant leak!! :(
    Oct 2011
    Prescott, AR
    Sorry to jack the jacked post, but I am working on my son's 2005 Grand Prix and EVERY stinkin hole has broken elbow rings in them. What do I use to get the rings out? Thanks!
    Last edited by davidinark; 05-27-2012 at 06:31 PM. Reason: edited because there are RINGS, not just pieces.
  9. #9 Re: Coolant leak!! :(
    i used a pick set like this, they sell for 5 bucks at harbor freight,or the parts store.
  10. #10 Re: Coolant leak!! :(
    Oct 2011
    Prescott, AR
    Ah! Thanks. My method (flathead screwdriver and a lot of /mental/ cursing) isn't really working. :-)
  11. #11 Re: Coolant leak!! :(
    Oct 2011
    Prescott, AR
    Anything that would help "eat away" or "melt" the plastic? Or should I just keep chipping away?
  12. #12 Re: Coolant leak!! :(
    i scraped all that crap out with the pick set i posted a pic of. worked good, then sprayed with brake cleaner and wiped down. lubed the new elbow O rings with some oil off the dip stick and they slid in like butter.
  13. #13 Re: Coolant leak!! :(
    Oct 2011
    Prescott, AR
    Perfect! Thanks. Guess I know what my Memorial Day will be spent doing... Certainly "Memorable."
  14. #14 Re: Coolant leak!! :(
    Oct 2011
    Prescott, AR
    I just want to say THANKS! Everything came out easier than I thought and went together even easier than the breakdown! Scottydoggs, you rock!
  1. Coolant Leak?!?
    By selym17 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-20-2013, 02:42 PM
  2. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  3. Coolant Leak
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-21-2011, 10:06 AM
  4. coolant leak
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2011, 11:56 PM
  5. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
