Thread: Cam or rockers? Topswap or HV3?
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: Cam or rockers? Topswap or HV3?
    This ^^^^^
  2. #22 Re: Cam or rockers? Topswap or HV3?
    Florida
    i disagree with installing a cam or rockers equal improved mpg. yes they allow more air, but with this comes more fuel. flow mods that do increase mpg are fixing flow restrictions. like headers, air intake, TB, porting of tb, LIM, heads. these allow the car to breath easier. cam and rockers cause the car to breath more... the only explanation i can think that would justify that a cam or rockers make better mpg is that they improve the usable power range. or that without proper fueling you are now getting more air at a lower rpm/tp% and the car is now leaner.
    if mpg is a concern, then your first major mods should be a wide band and tuner. you can aim for a safe conservative AF and then plan other mods from there.
    Ohio
    Quote Originally Posted by Z34Phoenix View Post
    ...the only explanation i can think that would justify that a cam or rockers make better mpg is that they improve the usable power range....
    Thats what I just said... There are plenty of 3.8s that are cammed or have rockers that are pulling upwards of 5mpg more than stock
  4. #24 Re: Cam or rockers? Topswap or HV3?
    What's a factory GTP rated at on the highway?
    Also...
    Ported heads and headers help a ton on the MPG side...FLOW FLOW FLOW.
    I saw 29 MPG AVERAGE on the way to the Iowa meet last year.
    Lean burn cruise tuning anyone?
    Exactly.
    440+ miles to a tank FTW.
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    Okay so I'm planning to get headers, and top swap. But while I'm top swapping I kind of wanna drop in a cam while I have everything off, which can would provide the most power while also not causing severe unreliability
  6. #26 Re: Cam or rockers? Topswap or HV3?
    Mar 2012
    NC
    VS, XP, S1X...all solid cams
  7. #27 Re: Cam or rockers? Topswap or HV3?
    Anything past 200 WHP can make it very easy to nuke a stock trans.
    VS is going to be the nicest to the valvetrain, lasting the longest.
    Mar 2012
    Minneapolis MN
    I thought the GT's had a stronger trans though?
  9. #29 Re: Cam or rockers? Topswap or HV3?
    than what?
    They're all the same.
    Mar 2012
    Minneapolis MN
    A stronger trans than the gtp, it's not the HD, or am I just being an idiot?
  11. #31 Re: Cam or rockers? Topswap or HV3?
    Out West
    Quote Originally Posted by Kolton Lock View Post
    Yes to the last part.
    Whine with your Cheese?
  12. #32 Re: Cam or rockers? Topswap or HV3?
    HD trans has a stronger differential. thats about it.
  13. #33 Re: Cam or rockers? Topswap or HV3?
    Out West
    The better question. What would ever lead you to believe the GT trans is better?!
  14. #34 Re: Cam or rockers? Topswap or HV3?
    it has a better gear ratio
  15. #35 Re: Cam or rockers? Topswap or HV3?
    Out West
    Not nesc.
  16. #36 Re: Cam or rockers? Topswap or HV3?
    Quote Originally Posted by Nixon View Post
    Not nesc.
    Better overall accel, but second gear with 2.92's is apparently the "sweet highway gear"
  17. #37 Re: Cam or rockers? Topswap or HV3?
    Out West
    yep.
  1. Topswap for $500?
    By mattstansbury in forum General Tech Discussion
    Last Post: 09-11-2011, 10:50 AM
  2. L67, L32, or L26 Topswap
    By timboku in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 11:46 PM
