Thread: Which MAF Sensor
Results 1 to 8 of 8
  1. #1 Which MAF Sensor
    SE Level Member rcman29's Avatar
    May 2012
    Kansas
    I'm trying to determine if the wrong maf was put on my car. I have a 2001 gt with 3800 and it has the afh50m-04, I'm wondering if it should be the afh50m-05 instead. The engine light is on because of that as i had it coded today. Any opinions anyone?
  2. #2 Re: Which MAF Sensor
    Does it run fine is the first question I'll ask you...
    All of the MAF's from 97-03 are the same...it's the throttle body's that vary.
  3. #3 Re: Which MAF Sensor
    What? Nick remember how the 97/98 has the post in the TB and the 99+ don't have the post. That makes the sensor different.
  4. #4 Re: Which MAF Sensor
    May 2012
    Kansas
    It stalls some when it's col,d but runs fine after engine is warmed up, both sensors look similar.
    1998 PONTIAC GRAND PRIX OEM MASS AIR FLOW SENSOR "AFH50M-04" | eBay
    NEW BUICK CHEVY GM MASS AIR FLOW SENSOR MAF 99-05 3.8L AFH50M-05 3 PIN PLUG | eBay
  5. #5 Re: Which MAF Sensor
    Got it backwards.
    Now were even for the mess up you had awhile back that I caught
  6. #6 Re: Which MAF Sensor
    Got it backwards.
    No, you read me wrong
    97/98 open the throttle body, there is a solid metal post. It's not part of the sensor, I meant..it had the post, therefore the sensor in that year has no bulky shield on it.
    99+ has no post in the TB structure and therefore has the plastic shielding as part of the sensor.
    Quote Originally Posted by rcman29 View Post
    They do from the top. Look at the part of the sensor that sticks into the TB. There's your difference that we are talking about.
  7. #7 Re: Which MAF Sensor
    i loaded up the does it fit section, it says this one will fit your car, the other is for a 98 wont work.
  8. #8 Re: Which MAF Sensor
    May 2012
    Kansas
    thanks guys, looks like the wrong one was put on my car by the previous owner.
  1. O2 Sensor not working... P0171 new sensor still no data from O2?
    By Z34Phoenix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-16-2012, 12:20 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
