Thread: Fans come on as soon as the car starts
Results 1 to 7 of 7
  1. #1 Fans come on as soon as the car starts
    Apr 2012
    NoWhere
    I have a 2001 pontiac grand prix 3.8 n/a only mod is a WAI i got off ebay, the one day out of the blue starting running very cold about 160-175 consistently before I would be running at around 195-210, I did out some hyper lube in it but I dont think this would cause the fans to always run as long as the car is on I always thought the fans would cut on at 195 but this car's fans come on as soon as you start the car
    Anyone ever heard of this happening?
  2. #2 Re: Fans come on as soon as the car starts
    Ontario
    Mine did that, it ended up being a stuck open thermostat. Same year, same engine. Also I should note it didn't throw an engine code until about a month or two after it was going on.
  3. #3 Re: Fans come on as soon as the car starts
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by mirving171 View Post
    I did out some hyper lube in it but....
    What is hyper lube and where did you put it? The fans should kick on around 220 or something. Are your defrosters on?
  4. #4 Re: Fans come on as soon as the car starts
    Stock fan settings are 214º and 226º IIRC.
    AC "on" will cause fans to run.
    Stuck open thermostat? For why it was running to cool?
    Possible sensor and or wire problem maybe?
  5. #5 Re: Fans come on as soon as the car starts
    I'm on the stuck thermostat band wagon
    I'm also on the ac or bad temp sender wagon
    Hell...I'll get on the beer wagon too.
  6. #6 Re: Fans come on as soon as the car starts
    Florida
    where is that beer wagon... it never comes around here!
  7. #7 Re: Fans come on as soon as the car starts
    Ontario
    It's so weird that the engine, in my case, didn't throw a code for a month or so after this same issue happened with me. Needless to say, as everyone here has advised, a) Check defrosters, AC what not to make sure none of 'em are on, then move on to T-Stat and gauge accordingly. Hope you solve it! Get her running warm again!
  1. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  2. 2001 Grand Prix GT starts then stalls then starts up and is fine???
    By 81X11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 10:29 PM
  3. fans fans fans
    By copperpacecar in forum General Tech Discussion
    Last Post: 11-03-2011, 08:44 AM
  4. starts without key
    By stlunatics2oo3 in forum General Tech Discussion
    Last Post: 10-23-2010, 04:16 AM
  5. Car never starts on first try but always on second try.
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 07:57 PM
