Thread: Intake Manifold
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Intake Manifold
    Quote Originally Posted by Rico View Post
    Does anyone make that bracket out of steel?
    Yeah, its called an L67 Coil Pack Bracket.
  2. #22 Re: Intake Manifold
    Apr 2009
    Fort Worth TX
    No, I was talking about the other one.
  3. #23 Re: Intake Manifold
    No, but most high powered builds like that...delete the DB's and run a transmission bell housing mount.
  4. #24 Re: Intake Manifold
    Apr 2009
    Fort Worth TX
    I see.
  5. #25 Re: Intake Manifold
    May 2012
    Indy
    Where dd that intake manifold come from? That looks far superior to my current plans...is that custom made? If not where is it from and is it still available? I guess I could make one if I had to...but at that point machining the L26 is more financially feasable...
  6. #26 Re: Intake Manifold
    hangover park IL
    The Holden intakes go fer around 300-900$ depending on what it comes with....
    ~James~ Psychotic Gearhead
  7. #27 Re: Intake Manifold
    GTX Level Member SomeDudeAtHome's Avatar
    Buffalo, NY
    So what would be the HP gains on an L36 with one of these? Would it be even noticable?
    Black 98 GT bought in summer of 2009 w/28K miles- GTX Rims, Retrofit headlights, tinted tails, 20% tint all around, KYB Excel-G's, WBS Lowering Springs, 33mm Dorman front sway bar, 22mm Addco rear sway bar, BMR trailing arms, BMR STBs front and rear, ZZP control arms, Poly motor mounts, ZZP CAI, Thrasher shift kit
  8. #28 Re: Intake Manifold
    hangover park IL
    Doubt it....the lower half is essentially an fbody intake with the upper half made for the holden engine bay constraints of the Holden Commodore which is nothing like the F body
  1. Which intake manifold?
    By SnowFlake in forum General Tech Discussion
    Last Post: 04-23-2012, 12:20 PM
  2. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  3. Which intake manifold is better?
    By ya61x in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2010, 11:51 PM
  4. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
  5. Intake manifold
    By joesforspeed in forum Turbo
    Last Post: 10-21-2008, 03:55 AM
