Thread: L67 coil mount/engine mount bracket (passenger side) on an L36
Results 1 to 7 of 7
  1. #1 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    No problem.
    My silver car actually had one on there when I bought it, so the P.O...probably got tired of swapping them...and I'm sure he did it more than once since the mounts I yanked out of the bottom of that car were beyond destroyed. That thing felt pretty solid with solid rubber motor/trans mounts, poly upper squares, stock DB bushings in the back, for the record.
    We need bill to show us that video proving W body mounts will never be as good as H body.
  2. #2 Re: L67 coil mount/engine mount bracket (passenger side) on an L36
    Hockey puck awesomeness.
  1. Oil pan gasket - removing 15 mm bolt at top/rear of front engine mount bracket - 2004
    By jkk9 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-31-2011, 06:40 PM
  2. The motor Mount on the passenger side of the motor.
    By Nuzzget in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-30-2009, 09:27 PM
