Thread: Is the intake gasket a problem on 2004 & newer 3800?
Page 1 of 3 123 LastLast
Results 1 to 20 of 51
  1. #1 Is the intake gasket a problem on 2004 & newer 3800?
    Feb 2009
    West Michigan
    My neighbor told me my wife's 2005 GP 3.8L (naturally aspirated) will most likely need an intake gasket at some point since the factory intake gaskets are kinda junky. He said anywhere from 80k miles on up they start having issues. My wife's has 132k. Is what my neighbor saying have any truth to it?
    Ohio
    05 came with aluminum gaskets so no worry.. He be uneducated lol just to be sure your car isn't an early 05/late 04, check around the end of the lim and heads to see if you see shiny gasket or black
    Mercer, Pa
    Look under water neck on engine, you don't have to remove anything. This is the easiest spot to look at gasket The gasket is 1/4" thick and will be dull aluminum cooler or black plastic.
    Might need a bright flashlight.
    Mercer, Pa
    Also. If you still have dexcool (deathcool) in it you are going want to flush the coolant system, it is probable pretty slimy.
    I flush with water a couple times over a week then fill with the green/yellow non dexcool.
  5. #5 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Your neighbor is educated, seems like a nice person trying to help you out. May not be up to speed like a bunch of 3800 nerds that spend their days on forums. =0)
    Take a look and see if your gasket is black or silver. Silver means you smile and be happy, black means should replace. As for Dex...I'm not a huge dex disliker. It will sludge up when exposed to air (at least the old versions did) and little stuff, but it doesn't cause the gaskets to break down and fail like many believed.
  6. #6 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Feb 2009
    West Michigan
    Thanks for the tips everyone! I will do some investigating tonight after work and hopefully see "silver" and not "black". As for the dexcool, I just had my mechanic friend put new hoses and a flush and fill and he suggested sticking with the Dexcool approved coolant. He said it is not the same formula as when it first came out and he has heard the stories/rumors of the original stuff eating gaskets and not eating gaskets.
  7. #7 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Apr 2009
    Fort Worth TX
    Question: Is DEXCOOL more friendly to aluminum. I heard it is. The last motor I rebuilt - filled it with the DEX. Did I do a no-no?
    GT Level Member afallucco's Avatar
    Ohio
    Quote Originally Posted by 99pgpgt View Post
    I found out while doing mine yesterday they didn't put the aluminum gaskets on until the 06 year.
    Sent from my ADR6400L using Tapatalk 2
    2004 Grand Prix GTP
    |FWI | HP Tuner | 1.9 Rockers | SD Headers | 3.5MPS | 97-03 control arms w/GMPP sway bar|
    Planned soon: s3x, custom ported heads, IC
    Thug life, that's how we live.
    Ohio
    Quote Originally Posted by Rico View Post
    Dex is fine with the aluminum gaskets, it eats away at the older gaskets. The fix for the dexcool problem as I said above was aluminum gaskets in 06
    2004 Grand Prix GTP
  10. #10 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Kansas
    Pretty much, every year of Grand Prixs were a Frankenstein car. Pretty much have to inspect everything yourself. Mine was an early '05 (Feb. '05) and had the black plastic LIM gaskets.
    If yours is black, ~$50-$70 for you to fix it yourself. Pretty simple and straight forward job.
  11. #11 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Quote Originally Posted by afallucco View Post
    This is the misconception. Dex doesn't eat the gaskets, the gaskets deform from heat etc and differences in metal from the aluminum LIM to the cast iron heads. The issue with dex is when it is exposed to air and turns back to oatmeal.
    Ohio
    Anthony you have an 04 -_- smh
  13. #13 Re: Is the intake gasket a problem on 2004 & newer 3800?
    And yes...Dex was originally formulated to work better with the addition of a lot of aluminum in the cooling system. As well, it's been quietly reformulated a couple of times over the years. Last change was in about 2008-2009 from what I had heard.
  14. #14 Re: Is the intake gasket a problem on 2004 & newer 3800?
    And here's an article I had read at one point that helped explain the issues and takes it out of only being a GM gasket issue by mentioning how many Ford and Chrysler's were effected.
    Closing The Gap on Intake Manifold Gaskets: Engine Builder
    It does mention coolant neglect as part of the issue along with heat etc.
    I have personally swapped out to different coolant with an hour long flush of clean water etc etc. Put plastic frammed back in (no others at the time) and used green coolant. 20K miles later pulled those gaskets to find them deforming and starting to degrade.
    GM and others put metal sleeves into the plastic gaskets thinking they were being over torqued, and finally came down to redesigning them near the end of the production of these motors. The fix.. a better gasket.
  15. #15 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Ohio
    Doesn't mean I didn't look into it just because I have an 04.
    2004 Grand Prix GTP
  16. #16 Re: Is the intake gasket a problem on 2004 & newer 3800?
    I'd look into it even if I had an 08.
    GM made changes, not necessarily by year. They made the changes more by when they ran out of a part in stock. The transmission is a perfect example. I've seen a 2003 car where the transmission didn't have the hardened 4th clutch hub. Why I'm not fully sure of.. it has production date of Nov 2002, but was a 2003 model. Which leaves the question out there.. is it 2003's built in 2003 that got the shaft or was it after GM ran out of the non-hardened ones? I'd bank on the latter.
  17. #17 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Ohio
    And thank you, I like learning new things everyday.
    2004 Grand Prix GTP
  18. #18 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Apr 2009
    Fort Worth TX
    Hmm, turned out to be a good thread.
  19. #19 Re: Is the intake gasket a problem on 2004 & newer 3800?
    St. Louis
    [QUOTE is it 2003's built in 2003 that got the shaft or was it after GM ran out of the non-hardened ones?][/QUOTE]
    I think most 97 to early 03 buyers got the shaft on that one, lol... Stupid bean counters.
  20. #20 Re: Is the intake gasket a problem on 2004 & newer 3800?
    Feb 2009
    West Michigan
    So my wife has the black plastic gasket set on her 05 What should I be watching for if this gasket starts to fail? She has about 132k on the GP right now.
  1. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. 97 Grand Prix Gtp Newer Superchager (Houston We Have A Problem)
    By 2DeepInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2012, 07:43 PM
  4. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  5. L32 (2004) 3800 Series III cover
    By mcg_999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 02:59 PM
