Thread: Time for new plugs and wires??
Results 1 to 14 of 14
  1. #1 Time for new plugs and wires??
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    So today I was on a little bit of a road trip and bout 20 mins in or so the RPM gauge jumped slightly and went back to normal. My dad was driving the car at the time and so I didnt really notice. He pointed it out and im like maybe it was just a fluke deal. It happened a couple and i knew something was up and it maybe happened 10 times or so that i noticed. None of which were that big of a deal but i figured if i let it go itll just get worse. My car currently has about 143,000 mi and i no for sure that the plugs and wires havent been changed in the last 23,000 and i am not sure if they have ever been changed or not. It seems like this would be a reasonable place to start in dealing with a slight misfire seeing as how things normally wear out over time. Im not too sure on how often plugs and wires need to be changed but i figured id post this to see if anyone has any second opinions on this.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  2. #2 Re: Time for new plugs and wires??
    Charles City, IA
    Do the wires have numbers on them?
    SMGPFC Two Nipple General
  3. #3 Re: Time for new plugs and wires??
    Mar 2012
    NC
    SES light on?
  4. #4 Re: Time for new plugs and wires??
    Jan 2012
    Philadelphia
    my car had a few issues so i changed the wires, i put on taylor 8mm pro wires and it worked great i love them wires but now its time for plugs
  5. #5 Re: Time for new plugs and wires??
    Quote Originally Posted by TheOtherNick View Post
    Not sure if there is or not. We just got back. I will check tomorrow in the daylight and get back to you on that.
    Quote Originally Posted by hitman92499 View Post
    SES light on?
    There is not SES light on at all.
  6. #6 Re: Time for new plugs and wires??
    Charles City, IA
    if they are numbered they are original. If so time to replace.
  7. #7 Re: Time for new plugs and wires??
    Mar 2012
    NC
    Check for ignition coil corrosion too. Very common on these.
  8. #8 Re: Time for new plugs and wires??
    They say PACKARD and then the number so thanks for that info. Any suggestions on wires? i see taylor has been suggested.
    Ok will do.
  9. #9 Re: Time for new plugs and wires??
    Charles City, IA
    Just stock replacement delcos are fine.
  10. #10 Re: Time for new plugs and wires??
    Are stock replacements the way to go on the plugs too?
  11. #11 Re: Time for new plugs and wires??
    GTP Level Member buickman104's Avatar
    NYC
    Might be a bad coil if the rpms bounce 1,000rpms. Billboost had that issue.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  12. #12 Re: Time for new plugs and wires??
    I'd remove the coils, clean the ICM, sand the coil terminals, add a little grease to them, get new plugs/wires. Stock ACD replacements for plugs/wires are great if you plan on staying stock or close to it.
  13. #13 Re: Time for new plugs and wires??
    Apr 2011
    Tally, FL
    how would you go about cleaning the icm do you just spray with sometype of cleaner? any certain type of grit for the coils?
  14. #14 Re: Time for new plugs and wires??
    1000 grit is what I've always used.
    And clean the ICM with a towel. That's it, just wipe it clean from dirt and whatever else is in there.
  1. plugs wires etc?
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 04:12 PM
  2. New to Forum, time for new plugs and wires
    By SBB in forum Introductions/Noob Questions
    Last Post: 08-17-2010, 04:49 PM
  3. Best plugs&wires for a 99 GTP
    By MurphysLaw in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2010, 08:58 AM
  4. Plugs and Wires
    By Squishy in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-09-2009, 09:51 PM
  5. New Spark Plugs and Wires
    By rileystanek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 02:31 AM
