It can be adjusted, by tuning the ECU. There is no way to do it otherwise, nor do you need to unless you have a crazy cam setup.
My rpms fully hot in park are right around 850. If your's is low or high then it may be time to clean the TB, MAF and IAC. Then check for vacuum leaks.
