Thread: Stock Spark Plugs
Results 1 to 17 of 17
  1. #1 Stock Spark Plugs
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    Are the stock spark plugs from ACDelco, Iridium or Copper? I noticed you guys said go with Autolite 606 Iridiums, or the $7 stock ACDelco plugs... but copper ACDelco plugs arent $7????
    2001 GT - Mods, Magnaflow Mufflers, K&N CAI
  2. #2 Re: Stock Spark Plugs
    St. Louis
    Yes, stocks are Irridium.
    And that price is for the Irridiums. As long as you stay away from any Bosch plug or any platinum plugs you're good to go.
  3. #3 Re: Stock Spark Plugs
    Sep 2011
    Fort Worth, Texas
    Alrighty, just wanted to verify that, Im the 3rd owner, so at this point I'd be shocked if it still had stock plugs.
  4. #4 Re: Stock Spark Plugs
    Yup, lifetime warranty wires as well...ditch the metal plug covers as well...
  5. #5 Re: Stock Spark Plugs
    Sep 2011
    Fort Worth, Texas
    It was your post I was reading for ideas, Im implementing some of your N/A suggested mods. And what metal plug covers, I honestly havent even looked at then yet?
    And um, quick question, my P0420 code popped up, I know thats a inefficency code for the cat, but what are the odds its an o2 sensor? Because with a quick glance yesterday, I noticed the o2 sensor isnt sitting level in the bong.
  6. #6 Re: Stock Spark Plugs
    There are metal covers over the plug boot that is supposed to keep it from "melting"...but they don't matter. Those along with like 19,565 different engine brackets you can pull off to make the job tons easier.
  7. #7 Re: Stock Spark Plugs
    Apr 2009
    Fort Worth TX
    Remove your O2 sensor from your bong and install in the bung on your exhaust system. That must a been a hell of a party you had there.
  8. #8 Re: Stock Spark Plugs
    Sep 2011
    Fort Worth, Texas
    Wow, I didnt mean bong lol, I have never typed bong, yet it manages to autocorrect to that. So my o2 sensor wasnt sitting in my BUNG correctly lol
  9. #9 Re: Stock Spark Plugs
    Apparently your phone wants you to smoke.
  10. #10 Re: Stock Spark Plugs
    19,566*
  11. #11 Re: Stock Spark Plugs
    Sep 2011
    Fort Worth, Texas
    Okay, one last thing... why do most of you run 104's when it says 606's or is the 104's for SC cars?
  12. #12 Re: Stock Spark Plugs
    Modded guys run 104's when they need to.
    You always want to run the hottest spark you can.
    So when you get to a certain mod point, the 104 become the best option.
    606's are stock heat range in the copper cores.
  13. #13 Re: Stock Spark Plugs
    Sep 2011
    Fort Worth, Texas
    So since I'm fairly stock, I should be running 606's then.
    Okay thanks DeathPunch
  14. #14 Re: Stock Spark Plugs
    How often do you want to change your plugs?
    The 606 copper cores will last 13-15k miles normally. And cost maybe 12-15 bucks per time.
    The ac delco iridiums will last 75-100k miles and run about 35-45 bucks.
    Its your call. I prefer the coppers, but I'm also slightly modded.
  15. #15 Re: Stock Spark Plugs
    Sep 2011
    Fort Worth, Texas
    Well I was going to get Autolite XP606 which is the Iridium Autolites, according to Autozone.
  16. #16 Re: Stock Spark Plugs
    Sep 2011
    Fort Worth, Texas
    And I dont want to change them often.
    Those are fine.
  1. Spark Plugs on '04
    By 04GT2 in forum General Tech Discussion
    Last Post: 08-10-2016, 12:34 PM
  2. spark plugs
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 09:44 PM
  3. NGK spark plugs for stock
    By Liquifire in forum General Tech Discussion
    Last Post: 03-29-2011, 04:00 PM
  4. Spark Plugs on a 05 GT
    By unwrittenlaw829 in forum 04+ Specifics
    Last Post: 12-07-2009, 12:48 AM
  5. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
