Thread: Idle speed
Results 1 to 6 of 6
  1. #1 Idle speed
    Aug 2011
    nj
    I have a 2002 3.8 n/a. Can the idle speed be adjusted and if so how? Also, what rpm's is the engine supposed to idle at.
  2. #2 Re: Idle speed
    St. Louis
    It can be adjusted, by tuning the ECU. There is no way to do it otherwise, nor do you need to unless you have a crazy cam setup.
    My rpms fully hot in park are right around 850. If your's is low or high then it may be time to clean the TB, MAF and IAC. Then check for vacuum leaks.
  3. #3 Re: Idle speed
    command at start up is around 1050
    Fully hot idle is 750ish and in gear around 650-700.
  4. #4 Re: Idle speed
    Wichita
    ^^^I'm so happy I stumbled upon this wonderful and very helpful reply.
  5. #5 Re: Idle speed
    idle can be adjusted manually. There is a set screw on the TB 97-03. However if you mess with this..it'll toss a code. Best way is in the PCM
  6. #6 Re: Idle speed
    Florida
    the screw on the TB is just a blade stop. the computer will just adjust the IAC to compensate for what ever you did the the set screw until the diff is too much.. then it will set the SES.
    like said you need a tuner to adjust the idle. so DHP or HPtuners.
    OP is there a reason you want or need to adjust the idle? maybe we can figure out another solution or help fix what is wrong.
  1. Random very high / fast idle speed...
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2013, 10:55 PM
  2. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  3. Replies: 7
    Last Post: 07-07-2010, 08:58 AM
  4. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
