Thread: Full Swap q's.
Results 1 to 20 of 29
  1. #1 Full Swap q's.
    Apr 2012
    Michigan
    Hey there everyone, new to the forum, popping my post cherry right now. My 98 gt spun a rod bearig, is knocking clanging and basically destroyed. So im looking to do a full swap. Ive lined up a used 3800 s2 with trans, only 74k miles for $365 (inorite steal:-) ). My concern is its out of a 95 bonny, but wouldnt drop in his 98 bonny. Any insight here would be useful gentlemen, since im new to the gp's. I'd hate to drive 200 miles, pick it up and have my mech say its a no go. Thank you
  2. #2 Re: Full Swap q's.
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    grab the PCM. The transmissions are different. You have the 4t65e and the other is 4t60e. Or you could just use your transmission I beleive. Where at in Michingan are you?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  3. #3 Re: Full Swap q's.
    Apr 2012
    Michigan
    This is what the guy told me.
    " The problem I had was the position of the spark plug. I guess the 96 motor were evenly spaced apart along with the exhaust and this one has two of them closer together changing the exhaust manifold.
    I'm in jackson
  4. #4 Re: Full Swap q's.
    Apr 2012
    Michigan
    I'm really only concerned if it will fit. i can sell the pcm and trans and honestly probably make a buck off the deal
  5. #5 Re: Full Swap q's.
    Jul 2011
    Michigan
    If it is a series 2 3.8 why wouldn't it fit. Same motor different car. Only thing different is the transmission which will also fit. May need a different trans mount but not sure.
    Edit: If your using your trans, then it will be a direct swap. The vac line routing is different for sure but it should be easy to switch. I wish one of the other members would chime in.
  6. #6 Re: Full Swap q's.
    Apr 2012
    Michigan
    I'm gonna jump on it then, hell if it don't fit for whatever reason I can still make a great profit off it
  7. #7 Re: Full Swap q's.
    Just make sure it's a series 2 3800 and not a series 1. I'm not sure what year they made the switch.
  8. #8 Re: Full Swap q's.
    Jul 2011
    Michigan
    Thats the only reason I can think of as to why It won't fit into his 98 Bonnie. Double check to make sure its a series 2 and not 1....Like ^^^said.
  9. #9 Re: Full Swap q's.
    Quote Originally Posted by Npost04 View Post
    I'm in jackson
    Then its not a series II, its a series I.
  10. #10 Re: Full Swap q's.
    Apr 2009
    Fort Worth TX
    ^^X2 I think some of the 95 WB platforms were built with the series II but if the exhaust manifolds are different then yea, it's a series I. I'm pretty sure all series II motors had the same bolt pattern for the exhaust manifolds and crossover. Only difference was the DP and the rest of the exhaust.
  11. #11 Re: Full Swap q's.
    its not a SII if the valve order isn't IEIEIE.
  12. #12 Re: Full Swap q's.
    Jersey
    its definitely a series 1, not to mention pre 96 was obd1
    16' wrx sti- stock
  13. #13 Re: Full Swap q's.
    Bonneville guru here.
    95 NA was S2
    95 SC was S1
    If this is an NA, then take the motor, it should be almost identical to yours with a couple big dumb brackets etc hanging off it. I'd keep your transmission, wiring and pcm. Just use the motor and it'll work just like your old one did.
  14. #14 Re: Full Swap q's.
    Apr 2012
    Michigan
    Heres the link to his ebay auction with pics 3800 3.8 V6 GM Engine & Transmission - 74,000 miles - 3.8 LT | eBay
  15. #15 Re: Full Swap q's.
    Apr 2009
    Fort Worth TX
    It looks like different manifolds than whats on the series II and the LIM/injector bungs look to be of a series I.
    Like matt5112 said: valve order IEIEIE?
  16. #16 Re: Full Swap q's.
    That's a 92-94 Series I NA motor. L27 is the motor designation. That motor came with either the black plastic upper that you see on that one or a metal upper (silver in color).
    That's not a motor you want.
  17. #17 Re: Full Swap q's.
    Northeast Ohio
    it even says its a series I in the title
  18. #18 Re: Full Swap q's.
    that's because I sent him a message and let him know.. He was going off what the guy told him originally. He sent me back an email thanking me.
    I worded it nicely.
  19. #19 Re: Full Swap q's.
    Apr 2009
    Fort Worth TX
    ^^^ I thought I was going crazy or my eyes were getting realy bad.
  20. #20 Re: Full Swap q's.
    Don't doubt your first instinct Rico...you probably are having issues..lol
  1. Full tank of fuel gauge floats between full and empty.
    By johnnyb in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2013, 06:17 PM
  2. GTP to CTSV Full Chassis Swap
    By crzystve42 in forum 04+ Specifics
    Last Post: 11-22-2011, 01:17 AM
  3. better gas mileage when tank is full/almost full
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 09:53 AM
