Thread: intake/head issue
Results 1 to 9 of 9
  1. #1 intake/head issue
    Michigan
    I am stumped and need some help. The engine is a 2005 seriesIII. Iron head, block, and aluminum intake upper and lower. The following iswhat I know:
    Taking in coolant
    Losing oil. Doesshow a small external leak but not sure if it is leaking as much as it is losing.
    No water incoolant
    Compression checkshowed 100 Psi in # 4 cylinder
    All others175-180
    Spark plugin # 4 look just like the others.
    Shows ahistory of a miss in # 4 but is not currently missing
    Strongexhaust pulse out the oil fill tube
    Oil in plenumto the point the air clean has oil on it. Not sure if this is due to an overoil file.
    This is my thought, slow leak in cylinder head gasket. Washeddown cylinder walls and took out rings. The problem is, these motors are notknown for blowing head gaskets. Also, I would think the spark plug would showsome signs of oil or water consumption. I would also think that with the amountof exhaust that is in the rocker cover, if caused by blow by, there would alsobe water in the oil.
    Any ideas would be appreciated.
    Thanks,
  2. #2 Re: intake/head issue
    Exhaust in the crankcase is the deal breaker isn't it. Yet you still have some compression. I'd pull it apart and take a look or get a borescope if you have the ability.
  3. #3 Re: intake/head issue
    St. Louis
    Pressure in the oil filler neck of the valve cover suggests a bad PCV valve. Also sounds like it's time for LIM gaskets. Take a look on the "front" of the motor (where all the pulleys are) and see where the LIM meets the block/heads. If the edge of that gasket is black, then its the plastic ones. If gray, then aluminum.
  4. #4 Re: intake/head issue
    Michigan
    Quote Originally Posted by FordMan77 View Post
    I changed the intake gaskets over the weekend but due to not having the car longer I came up short of pulling the head. It is the rear head in question. The intake ports were coated with carbon other then where the injectors sprayed. No positive signs of water. I did an intake on my 1998 and it had distinct water flow lines.
    I shook the PCV valve and it rattled and I could blow through it so I did not change it.
    I am still waiting to hear if it is still using water.
  5. #5 Re: intake/head issue
    Did the pcv have it's lower o-ring in place?
  6. #6 Re: intake/head issue
    Michigan
    That is a good question. I never removed the PCV valve from the upper. Just shook the upper to see if it rattled.
  7. #7 Re: intake/head issue
    That is one way to keep from breaking that silly NA plastic pcv cap. Although if it's just starting this issue.. likely something happened inside.
  8. #8 Re: intake/head issue
    Michigan
    Not sure how long it has been going on. My daughter is 21 and thinks if her car gets her from point "A" to point "B" then that engine light that goes on every ounce in a while must not mean anything.
  9. #9 Re: intake/head issue
    I have a neighbor kid I put a car together for. She wants tint, headlights and other bs cosmetic stuff. Meanwhile I made her a list that started with spare keys and ended at wheel bearings and AC seal kit. I understand ...trust me.
  1. cracked head blown head gasket or just done??
    By roytoy70 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 10:40 PM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. intake issue.
    By clevelandfan in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-16-2010, 07:37 AM
  4. Intake or Head Gasket?
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-22-2010, 03:11 PM
