Thread: Need help big time...please
Results 1 to 12 of 12
  1. #1 Re: Need help big time...please
    GTX Level Member cerick08GP's Avatar
    FWIW, I’m right there with Nighthawk and Slow. And I would like to add to FFDP’s comment.
    I can’t even come up with a good guess as to how many people come on this site with self generated ignition issues. I’d start by re-checking your spark plug work. Are the spark plugs the proper heat range and gap? You were a tech so this is all 101 stuff. Anyway, one more area you should consider is if you are leaning out too much from an air leak or EGR failure. Did you install something cocked or forget to connect a tube?
    Keep us posted plz.
    On a side note, not that anything you have done is 100% a bad idea. IMHO adding anything to your motor oil is neither a good idea nor necessary, especially considering your oil change intervals. And ya, AC Delco filters are NOT what they used to be
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  2. #2 Re: Need help big time...please
    Jul 2010
    upstate NY
    WOW! Thanks for all the responses.
    1. As far as spark plugs I installed Bosch + 4's..What should I use? I know my Hemi only runs good on plain ole Champions..is there a specific plug that these cars like?
    2. Car is bone stock..no intake work has been done and theres no evidence of a cracked header
    3. What oil filter do you guys use if not Delco?
    4. Checked all of the injectors, cleaned MAF, cleaned throttle body twice..most recently was 3 days ago, cleaned EGR and PCV..no codes from either, new air filter and no Vac leaks..LIM gasket is not leaking yet and I have no loss of anti freeze as well as none in the oil..
    5. I have not moved the fuel injector or checked fuel pressure..(what a dummy I am..lol) will do that today as well as change the fuel filter
    6. All of the injector wiring looks good..
    7. Spark plugs are correct for the car except that they're Bosch + 4's and I agree with you on adding anything to the oil..made me sick when I did but the tapping noise and the miss is driving me nuts..lol..I checked the EGR valve 3 or 4 times in the last couple of months..i even unplugged it and took it for a ride to see if it made a difference..it really didnt and that was the 1st time I got a code for the EGR...Im thinking I should just change the EGR anyway but I'm leaning towards a sticking lifter because of the noise (which does go away when she warms up) and the fact that the miss is intermittent...Im kinda stumped..also, thanks for the vote of confidence about me being a tech for many years but I failed to mention that I gave it up for a Law Enforcement career..20 yrs and out..collecting my pension..so I most likely forgot more than I remember and may not be up on alot of the electronics anymore..my history is also limited..only worked at a Chrysler dealership and although i believe all cars are pretty much the same I dont know the quirks of these particular cars.
    So, what do ya think now? Gonna do the fuel filter today and swap injectors..anything else?? Thanks to all of you guys again for responding..youre all awesome..
  3. #3 Re: Need help big time...please
    Pennsylvania
    Quote Originally Posted by 04gt2inny View Post
    Both of those are trainwrecks of spark plugs. Misfire city. No likey. Only ever, ever, ever ngk, autolite, or delco in a 3800. Use the iridiums. Never ever ever platinum. We have exhaust-spark ignition, which just chews through spark plugs.
    I use Fram XG. Gold can. Best value filter to me. Other folks dig WIX, Mobil-1, K&N... but there's cheaper. Even the Fram orange cans are better than Delcos. Check this study: GM Truck Central Oil Filter Comparison Study
    I think you're safe there.
  1. 1st time potiac, long time gm....
    By chernoble in forum Introductions/Noob Questions
    Last Post: 09-28-2011, 04:08 AM
  2. Long time owner/first time poster!
    By brez in forum Introductions/Noob Questions
    Last Post: 08-08-2011, 04:58 PM
  3. Long time reader, first time poster.
    By KeithGTP03 in forum Introductions/Noob Questions
    Last Post: 01-27-2011, 12:55 AM
  4. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  5. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
