Thread: Aftermarket Motor Mounts?
Results 1 to 5 of 5
  1. #1 Aftermarket Motor Mounts?
    Apr 2012
    Regin, SK, Canada
    Anyone know a good online site to get aftermarket motor mounts? My stock ones are squeeking and wore out. Figured I'd try for something better than the stock OEM replacements if they exist.
  2. #2 Re: Aftermarket Motor Mounts?
    I live here. TLSheff's Avatar
    INTENSE-Racing.com: Hydraulic Motor Mount
    INTENSE-Racing.com: Hydraulic Transaxle Mount
    If you need the uppers, you have options for either regular replacements or poly replacements.
  3. #3 Re: Aftermarket Motor Mounts?
    ^^Negative.
    Hydraulic ones are what you want to stay away from, because they are fluid filled...and fail over time, so you'd be back to square one.
    RockAuto.com sells solid rubber replacements...and they are cheaper...so get those. It'll also give better feel for the drivetrain and transfer power better to the ground as well. I'd get those along with flipping the upper dog bone mounts 90*, which is found in the link in my signature about modding.
    I have a solid transmission mount and a fluid filled motor mount with poly uppers in my silver car, its pretty solid although there is still a little movement under throttle, which the solid rubber engine mount should fix. The blue car in my signature however had poly engine/trans mounts along with poly uppers...and it didn't budge at ALL. Even under WOT conditions, but wooooo...was it rough.
  4. #4 Re: Aftermarket Motor Mounts?
    GTP Level Member
    springfield IL
    So whats the best way to go for just a replacement..??? Car is bone stock...I dont want any vibrations at idle.. what would be a good stock replacement mount(s).????
  5. #5 Re: Aftermarket Motor Mounts?
    Quote Originally Posted by tc300 View Post
    Hi guy, read post above you.
    ^^Negative.
  1. Motor Mounts
    By Classy Pontiac in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2012, 03:25 PM
  2. Torque strut mounts. Aftermarket?
    By CD Performance in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2012, 01:57 PM
  3. motor mounts
    By Chizzler in forum Brakes/Suspension/Chassis
    Last Post: 05-23-2010, 08:10 AM
  4. Motor mounts
    Last Post: 05-14-2010, 08:13 PM
  5. Motor Mounts
    By trailshredder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-24-2010, 02:43 PM
