Thread: Motor questions, installing a supercharger
Results 1 to 18 of 18
  1. #1 Motor questions, installing a supercharger
    Aug 2008
    Denver, CO
    Is there any way to supercharge and normal 3.8l v6, and is so what would it take.
  2. #2 Re: Motor questions, installing a supercharger
    SE Level Member snap on's Avatar
    Feb 2008
    Anchorage Alaska!
    Quote Originally Posted by dirtracer007 View Post
    If you have the L36 motor (newer GP) then you cannot add a supercharger. The motor already has a 9:1 compression. You need bring the compression down before you can add a supercharger onto it. I also have not seen any aftermarket superchargers for the newer gp.
  3. #3 Re: Motor questions, installing a supercharger
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Quote Originally Posted by snap on View Post
    What?
  4. #4 Re: Motor questions, installing a supercharger
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by VinnieGTP View Post
    What?
    Yeah, I completely missed reading that. Now that I see it...
    Wat?
  5. #5 Re: Motor questions, installing a supercharger
    GTX Level Member 02BlueGT's Avatar
    Hoffman/Schaumburg, IL
    9.5:1 I thought..... and higher compression supercharged, just means a little more power on the same boost and a little less timing
    2002 GT...CAI, Headers, Special Eddition two-tone leather interior added, HUD added, 12" Brake Upgrade, ZZP strut tower bars, gmpp sway bars, poly motor mounts, -6an braided SS fuel hoses , Hptuned, Headers, Top Swaped, 50lb inj, E85, 3.4
    I've got Boost!! Top swap Quesions? Click Here
  6. #6 Re: Motor questions, installing a supercharger
    Barksdale AFB, LA
    Like your other posts on the subject, that's typical of a programmed "Mr. Goodwrench" response who knows little to nothing about it.
    1.) The L36 is not in the newer GP (actually the L26, L36 was 97-03 GPs, 00-05 Impalas, and some Regals that I can't remember the exact years).
    2.) The L36 and L26 are 9.5:1 compression engines.
    3.) The compression does not need to be changed.
    4.) Aftermarket superchargers are not needed when we have our choice of either a Gen III Eaton M90 or Gen V Eaton M90 which GM already handily made compatible with our engines.
    2009 Subaru Impreza WRX STI
  7. #7 Re: Motor questions, installing a supercharger
    Quote Originally Posted by Sabrewings View Post
    YAY, I was Right
  8. #8 Re: Motor questions, installing a supercharger
    Feb 2008
    Anchorage Alaska!
    See what i was told was that on these engines that if you add any kind of forced induction it will burn up the motor like none other. All of the mechanics in my shop have said the same thing. I have a 2005 GP and i cannot find anything for the car. I want to make it fast and I want to supercharge it but i cant find a supercharger for my motor that i have. I sent out a thred a while back and everyone said that zzperformance had it but I could not find them anywhere what so ever. I also wanted to change the heads and camshaft out and change out the PCM and beef up the tranny. But i cant find anything anywhere.
  9. #9 Re: Motor questions, installing a supercharger
    Jersey
    lol, u shouldnt bring your car to these mickey mouse garages. Your "mechainic's" (aka goof troop) are smoking crack.
    16' wrx sti- stock
  10. #10 Re: Motor questions, installing a supercharger
    Donating Users blowfishRus6's Avatar
    g.a.
    and just so you know pretty much EVERYTHING for the 97-03 gp will fit on the 04+ the only difference that i can think is we have different style throtle bodies. im sure they have those too. camshafts, rockers, exhaust all fit our car as well as the older gp's. you can also get a built tranny from tranny man also.
    your mechanics are retarted.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  11. #11 Re: Motor questions, installing a supercharger
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    Sure you can.....
    ZZ Performance
  12. #12 Re: Motor questions, installing a supercharger
    Banned
    Quote Originally Posted by crimpton View Post
    Sure you can.....
    ZZ Performance
    x 2
  13. #13 Re: Motor questions, installing a supercharger
    Bastard Reptile's Avatar
    Kansas City, MO
    Someone's on crack.
  14. #14 Re: Motor questions, installing a supercharger
  15. #15 Re: Motor questions, installing a supercharger
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    meth. better than crack.
    H ftw
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  16. #16 Re: Motor questions, installing a supercharger
    Banned
  17. #17 Re: Motor questions, installing a supercharger
    Las Cruces, NM
    Having an 05 "should" make it even easier as you're already drive by wire and shouldn't need to mess with the TB and or MAF. You'll need a Gen V blower and LIM and the rest of the pulley and brackets from the L67/L32.
  18. #18 Re: Motor questions, installing a supercharger
    Barksdale AFB, LA
    They're idiots. Factory non-supercharged 3800s run around with turbos and/or superchargers every day and they're fine.
    ZZP has what they call the L36 SS M90 kit. It allows you to bolt a Gen III M90 (from the Series II 3800) onto a L36 (Series II 3800). I'm not sure if it's compatible with the Series III engine like you have, but that doesn't mean the engine will "burn up".
    ZZPerformance
    http://www.intense-racing.com/
    W Body Store - Don't Take SLOW for an answer!
    3800 Performance - high performance aftermarket car parts for your Grand Prix, Monte Carlo, Impala, Regal, Bonneville, and V6 F-body!!
    I don't see how that makes it any easier. He still has to pull the heads for L67/L32 heads to do a top swap.
  1. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
  2. trouble installing halfshaft
    By ShouldaGotTheGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-10-2008, 05:14 AM
  3. Installing rear rotors
    By wipeout48 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2008, 11:25 AM
  4. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
  5. Report: Motor Oil In The Supercharger Snout
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2008, 07:32 PM
