Thread: i make wa baypass for the coolant to the throttle body opinions
Results 1 to 7 of 7
  1. #1 i make wa baypass for the coolant to the throttle body opinions
    SE Level Member gpracing's Avatar
    Dominican Republic
    I made the bypass for the coolant that heats the air that goes to the throttle couse in my country the weather is tropical and is not to cold and i wanna know if this mod is better and if the mod upgrades my cars in something am new in this please any advice or opinion will be welcome.
  2. #2 Re: i make wa baypass for the coolant to the throttle body opinions
    Barksdale AFB, LA
    Not sure how you made the "bypass", but if you just blocked it you are starving your rear head of some coolant. The coolant through the throttle body is calibrated with another passage in the LIM to deliver the right amount. If you stop one, you've reduced the amount of coolant reaching the rear head.
    2009 Subaru Impreza WRX STI
  3. #3 Re: i make wa baypass for the coolant to the throttle body opinions
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    True but not a big deal. You can just remove the side cap on teh LIM and knotch it so more goes through that way, that's what I and others do to compensate for that.
  4. #4 Re: i make wa baypass for the coolant to the throttle body opinions
    Barksdale AFB, LA
    Quote Originally Posted by VinnieGTP View Post
    Yes, I forgot to mention the solution. But, doesn't that require removal of the LIM so you're not getting shavings into the cooling system?
  5. #5 Re: i make wa baypass for the coolant to the throttle body opinions
    Las Cruces, NM
    Quote Originally Posted by Sabrewings View Post
    I did, but I'm sure it can be done on the car as long as you have a shopvac and a garden hose to flush it out the hole when you're done.
  6. #6 Re: i make wa baypass for the coolant to the throttle body opinions
    Dominican Republic
    Well my friend did that to the camaro he owns and it works good and the car runs well a did it´s only for prove i didn´t prove it couse am waiting for the PCV sensor that i buy so when i install the sensor and prove the car i will tell you !
  7. #7 Re: i make wa baypass for the coolant to the throttle body opinions
    Dominican Republic
    ok , i see
  1. Throttle Body, worth it?
    By N3p in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2011, 03:12 PM
  2. Stock Throttle Body O.D.?
    By IndeedSS in forum General Tech Discussion
    Last Post: 09-03-2008, 04:26 PM
  3. Opinions on possible coolant leak
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2008, 11:00 PM
  4. Throttle Body swap
    By Berger in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-23-2008, 08:35 PM
  5. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
