Thread: Rerouting Wires
Results 1 to 20 of 20
  1. #1 Rerouting Wires
    GT Level Member ShadowSwept's Avatar
    Kentucky
    I don't know if the Pontiac wiring was this screwed up to begin with, or if whoever pulled the engine before I bought the car needs to be smacked, but this is rediculous. There's a mass of wires between the engine and firewall with no heat shield, some running through and melted to the exhaust manifold and others resting on the valve cover. There's also wiring stretched tight against the underside of the engine and more resting against the belt.
    I've already rerouted the spark plug wires, and I'm about ready to rewire the whole engine. I know people have rerouted for a cleaner look before, which is what I'm going for for now until I can afford performance mods, so if you guys could post some pictures of your reroutes along with some suggestions I'd appreciate it. I do want to clean up the appearance as much as possible, but keeping the wires from melting and/or shorting out is the first priority. Please help .
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Rerouting Wires
    http://www.grandprixforums.net/crazy...uck-48328.html
    Check that out if your really wanting a clean look.
  3. #3 Re: Rerouting Wires
    Kentucky
    Very nice, but he didn't finish, and the other side is what I'm more concerned with . Also, no need to go that extreme. I'm fine with the placement of the battery and coil packs, just not the wires running over, under, and around the engine. It seems like I find a new wire melting every day.
    2003 Grand Prix GT
  4. #4 Re: Rerouting Wires
    he did finish. he has been driving his car for a while.
    he just didnt take any pictures afterwards, which ruins it.
  5. #5 Re: Rerouting Wires
    Kentucky
    Yes, no pictures is a problem.
    Anyone care to post pics of their wire tucks?
    2003 Grand Prix GT
  6. #6 Re: Rerouting Wires
    It's not like that from the factory. Likely if you look at it, you'll see where it belongs w/o being stretched etc.
  7. #7 Re: Rerouting Wires
    Kentucky
    Didn't think so. Shouldn't be too much of a problem, but I'd like to clean up a bit while I'm at it of anyone's found some nifty way of doing things
    Need to make room for headers and keep wires off hot stuff
    2003 Grand Prix GT
  8. #8 Re: Rerouting Wires
    That's pretty easy to do.
  9. #9 Re: Rerouting Wires
    Kentucky
    Forgive my ignorance of terminology for a moment, but there are two sensors on the exhaust, one near the downpipe and a second in the U-bend near the cat. The wire leading to this second sensor was wrapped completely around the exhaust and the heat shielding had melted.
    I fixed it no problem, and fortunately the wires hadn't melted, BUT of the four wires leading into the connector the pink and purple wires were completely disconnected - even the pins were gone.
    So... How important is this sensor, and if I plan on getting headers and going catless can it just be deleted?
    2003 Grand Prix GT
    Jan 2009
    Tallahassee, FL
    Keep the first O2 sensor, that's the important one. The second just tell the PCM if the cat is working or not. Deleting it will throw a code but wont affect how the car runs.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  11. #11 Re: Rerouting Wires
    Minnesota
    Quote Originally Posted by Sandman View Post
    The car might not run correctly by just deleting the code that sets the check engine light. You might also have to change some other stuff in your file as far as turning the tests off and deleting the O2 out of the file.
  12. #12 Re: Rerouting Wires
    Kentucky
    Thanks, that's what I thought. To delete can I just cut the wires or do they need to be looped?
    I can tune out the code when I get a new PCM, right?
    2003 Grand Prix GT
    Jan 2009
    Tallahassee, FL
    You can leave the wires hanging or get an O2 sim like I did for a while and you can get any code tuned out.
    77 Morris Garage B
  14. #14 Re: Rerouting Wires
    Mine are cut because they didn't like being pinched in my header and decided to burn in half so I but them and they just hang there.
  15. #15 Re: Rerouting Wires
    Only if it's an 01+
  16. #16 Re: Rerouting Wires
    Minnesota
    Only if it's an 01+
    2003 Grand Prix GT
    3800 L36 N/A HAI
    169k miles
  17. #17 Re: Rerouting Wires
    I guess i should pay attention to little things like that lol
  18. #18 Re: Rerouting Wires
    Kentucky
    So if I go catless and delete the O2 from the PCM, do I need to keep one O2 sensor to keep things running well (or a least use a simulator), or can both be deleted?
    2003 Grand Prix GT
  19. #19 Re: Rerouting Wires
    You need the front one for sure it's the important one.
  20. #20 Re: Rerouting Wires
    Minnesota
    You need the front one. The downstream one you can either leave in or buy a plug and plug it after you correct for it in the PCM.
  1. Where to run wires
    By timreams in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2012, 06:06 PM
  2. Replies: 2
    Last Post: 01-18-2011, 01:00 PM
  3. ZZP 10.3 wires
    By Jakescoots in forum General Tech Discussion
    Last Post: 12-17-2010, 06:05 PM
  4. PRJ wires
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 04:46 PM
  5. zzp wires vs. prj wires...
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-06-2008, 10:18 PM
