Thread: LIM antifreeze leak
Results 1 to 9 of 9
  1. #1 LIM antifreeze leak
    Mar 2012
    Minnesota
    Just replace upper and lower intake gaskets. Not even a mile after I put The gaskets in and drove it antifreeze started leaking from the transmission side of the engine. I'm not driving the car now obviously but do I have to take the intakes off again. I sealed it with rtv in the corners but it's not leaking oil now. But antifreeze. Help, on a budget and can't afford a town.
  2. #2 Re: LIM antifreeze leak
    TB gasket leaking?
    Thermostat housing gasket leaking?
    Or its leaking coolant out the side where the LIM meets the block?
  3. #3 Re: LIM antifreeze leak
    Mar 2012
    Minnesota
    I'm not 100% sure because I can't see where the leak originates. When I put the engine back Together I replaced the tb gasket and I did check the thermostat housing. It seems like its underneath where the LIM meets the block, but when I set the in
    take in the gasket was still sitting in place perfectly. Also if there is antifreeze flowing out wouldn't that mean its going through oil to reach the edge however it's moving.
    Ohio
    What about the lim cap on that side??? Did you replace that gasket?
  5. #5 Re: LIM antifreeze leak
    Mar 2012
    Minnesota
    Where is the cap? The rectangle piece of metal near the EGR system?
    Ohio
    You got it
  7. #7 Re: LIM antifreeze leak
    Mar 2012
    Minnesota
    I didn't replace the gasket on that, I didn't take it off thought either. Anyway I can get at it without taking the intakes off?
    Ohio
    Yeah but you'll be able to tell if that's it.
  9. #9 Re: LIM antifreeze leak
    Mar 2012
    Minnesota
    Well I cant tell if that's leaking because the exhaust is in the way and so is the tb. Tomorrow I will take off the tb and check. I sprayed the intake with carb and choke cleaner to get deposits off, could that ruin the caps gasket? When I drove it yesterday for a mile it barely leaked and but I drove it today for less than a mile and way more anti freeze came out, it's all over the transmission. Think it's the cap? I have the gasket from the kit I bought but I didn't think to stitch it for some reason...
  1. antifreeze leak question
    By gentrymartin in forum General Tech Discussion
    Last Post: 03-12-2012, 02:37 PM
  2. antifreeze leak
    By dirtdriver11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2011, 08:50 AM
  3. I have an antifreeze leak coming from the intake
    By lzicc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2010, 01:36 PM
  4. antifreeze leak..
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:36 PM
  5. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
