Thread: 94 buick lesebre cuts out during acceloration.
Results 1 to 6 of 6
  1. #1 94 buick lesebre cuts out during acceloration.
    GT Level Member natethegreat's Avatar
    Brookings, SD
    We this buick will seem to cut out during acceloration yet it idles and runs. you hit the gas and its like the throttle boty doesn't open. and it has a flucuating idle. would you have an idea of what this is? Its sounds like the maf to me..
  2. #2 Re: 94 buick lesebre cuts out during acceloration.
    new britain, ct
    could be the MAF or the IAC
    07 Black GXP.
  3. #3 Re: 94 buick lesebre cuts out during acceloration.
    Brookings, SD
    Thats what i was thinking. how would you check for this? And i forgot to add this happens when it gets real hot outside. It was 80 today.
  4. #4 Re: 94 buick lesebre cuts out during acceloration.
    Maf?
    need a tune up?
    could be clogged cat aswell.
  5. #5 Re: 94 buick lesebre cuts out during acceloration.
    Brookings, SD
    Well it probably needs a tune up, and the clogged cat could very well be it. Ill have to check tomarow. Thanks for the help!
  6. #6 Re: 94 buick lesebre cuts out during acceloration.
    St. Louis
    If the plugs and wires are suspect, then start there. Also clean the MAF. If the idle still won't hold then check for vac. leaks. My 95 Bonne was like this when I got it and all it needed was a tune up and one vac. line that comes off the TB replaced (it was cracked) and it runs like a top.
  1. Air Conditioning fan cuts out at 3500 RPM
    By wburns in forum Introductions/Noob Questions
    Last Post: 06-14-2011, 09:32 AM
  2. Car cuts out under boost w/ vids
    By glanzergtx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2011, 06:50 PM
  3. Engine surges and cuts out
    By timmyg in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-02-2010, 04:26 PM
  4. Engine cuts out
    By DLAVENGER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-25-2010, 10:07 PM
  5. @115 Engine Cuts out
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 08-23-2008, 09:51 AM
