Thread: Major coolant help need quick answer
Results 1 to 19 of 19
  1. #1 Major coolant help need quick answer
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    I got our coolant elbows fixed yesterday and today we need some more coolant. Since the guy did not put enough. The coolant he put in our car is a gold coolant for what I think is for ford cars. It's it ok to mix with prestone coolant green/ yellow 50/50.
    2007 Pontiac Grand Prix Base - Sold
    2007 Chrysler Aspen 4.7 - Current Car/Family SUV
  2. #2 Re: Major coolant help need quick answer
    Feb 2010
    TN
    What was in there first? Dexacool, or the regular green,
  3. #3 Re: Major coolant help need quick answer
    If he flushed it already and put yellow in there, thats fine, its a all makes all model coolant, just toss some more yellow or green in there. Dont buy that 50/50 junk, its water really, get a full thing of conetrate and mix it yourself.
  4. #4 Re: Major coolant help need quick answer
    its 50% coolant and 50% water.
    Which is what it should be for most climates.
  5. #5 Re: Major coolant help need quick answer
    Jan 2012
    Anaheim, Ca
    Well we got the 50 50 and put it in, its like a light yellowish greenish color and just put some in the reservoir is it ok? we kinda dont want to waste time mixing it, just pour it and thats it and done and yes it was flush and the guy put a gold one in there which i think is for fords lol
  6. #6 Re: Major coolant help need quick answer
    Feb 2010
    TN
    If he flushed you should be ok
  7. #7 Re: Major coolant help need quick answer
    Jan 2012
    Anaheim, Ca
    Quote Originally Posted by Logan541 View Post
    Ya he did do a flush so ya pretty much put in a hose and pumped out the crap and put in new good one and then i just topped it off with 50 50, Ill remember to buy the whole next time then and what just mix it with water buy however much i put in?
  8. #8 Re: Major coolant help need quick answer
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    i don't get why people by 50/50. Buy 100% and you get 2 gallons of coolant instead of 1.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  9. #9 Re: Major coolant help need quick answer
    Jan 2012
    Anaheim, Ca
    Well i keep that in mind next time, thanks. So the 50/50 i just used is ok right?
  10. #10 Re: Major coolant help need quick answer
    Feb 2010
    TN
    Quote Originally Posted by BlackGT97 View Post
    I know basically the company figured out how to charge a high price for water
  11. #11 Re: Major coolant help need quick answer
    St. Louis
    I usually keep an empty coolant bottle around. Then when I get a new gallon, I pour half in the empty and keep half in the new one. Then fill them both w/ water and wallah! 2 gallons of 50/50.
  12. #12 Re: Major coolant help need quick answer
    Jan 2012
    Anaheim, Ca
    ill keep that in mind.
    One last ? i think, are reservoir went empty like 3 times when we checked it and nothing happened, so we filled it up and then it stay where its at like right on that line. Then i found out it all does go into the engine and will show the reservoir being empty, but now it shows it being at the line so is it ok? Like it wont add pressure to anything or break anything for having a little bit more in there. its at the line but i know it should go up when cooling.
  13. #13 Re: Major coolant help need quick answer
    St. Louis
    The resivoir can be filled past the line to a point and no worries. I did this when I had a coolant elbow leaking and couldn't get to it right away. No, it won't add pressure to the system. The rad cap is what holds the pressure in the system. If it gets too hot the cap will open and allow the coolant to flow out of the rad. and into the resivoir.
  14. #14 Re: Major coolant help need quick answer
    Jan 2012
    Anaheim, Ca
    Ya we just got the coolant elbows fixed and hopefully everything is good now. Thanks for your guys help my GP is now well again
  15. #15 Re: Major coolant help need quick answer
    St. Louis
    Good to hear. Wanna come out and fix mine since you're a pro at it now, lol...
  16. #16 Re: Major coolant help need quick answer
    Jan 2012
    Anaheim, Ca
    Would love to i charge 700$ an hour, and i will take my time lol JK. A mechanic had done most of the work BTW.
  17. #17 Re: Major coolant help need quick answer
    St. Louis
    Luckily I do all my own work, normally. Hernia surgery a few weeks back has all my repairs on hold unfortunately. Can't really bend over the fender long enough to change them out properly. Hope to god they hold a little longer, lol.. My spare car is still in the garage with her butt in the air and fuel tank on the ground. Hopefully no one has seen Murphy around.
  18. #18 Re: Major coolant help need quick answer
    Jan 2012
    Anaheim, Ca
    lol, i wish we can work on our car. We need a whole lift and money so we could work on our car, we could do so many things with the car lifted. Good luck with you car bro.
  19. #19 Re: Major coolant help need quick answer
    truth is, you dont NEED a lift. anything that you can do on a lift can be done with jack stands. when bill did my tans swap, the old one was out in 1.5 hours, not kidding. working on the floor.
    granted a lift will spoil you.
  1. Major Coolant Leak
    By Autoworks in forum General Tech Discussion
    Last Post: 03-13-2012, 12:23 AM
  2. coolant to water? help quick.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-27-2010, 10:12 PM
  3. need a quick answer will these fit??
    By tjsmithey in forum Tires & Wheels
    Last Post: 02-14-2010, 09:09 PM
  4. Quick Question, Easy Answer (bolt size)
    By alexsmith0913 in forum General Tech Discussion
    Last Post: 08-22-2009, 05:25 PM
  5. Help quick! Coolant bleed?
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2009, 08:14 PM
