Thread: knocking
Results 1 to 20 of 32
  1. #1 knocking
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    my engine started to knock after comming from work at first it was loosing power the rpms would go up and it would int advance at a stop the engine died I started and it kept knocking I check the oil because when I would press on the gas and on the dic it would read low oil pressure. I removed the belt and the knock its still there and the higher the rpm the louder it gets need help
  2. #2 Re: knocking
    Motor is done for.
    You most likely spun a rod bearing.
    Time to find a used motor and swap it in.
  3. #3 Re: knocking
    May 2011
    El paso tx
    how can I find out I spun a bearing? how does is it look if I remove the oil pan?
  4. #4 Re: knocking
    GT Level Member GMCustomerService's Avatar
    Michigan
    What year and model?
    Louis
    GM Customer Service
  5. #5 Re: knocking
    bad.
    You'll see which connecting rod spun the bearing and ground up the crankshaft.
    Metal flakes will be in the oil. Like glitter.
  6. #6 Re: knocking
    May 2011
    El paso tx
    its a 2004 grand prix, I don't really se the oil like with metal flakes
  7. #7 Re: knocking
    Yeah that may be.
    But you had said, the motor was knocking, it shut off on you. You cranked it over and it was still knocking. Low oil pressure light came on, took the belt off and still knocking. The higher the RPM's the louder the knock is.
    All that leads me to say the motor is toast and it spun a bearing or two.
    Time to look for a new used one.
  8. #8 Re: knocking
    May 2011
    El paso tx
    thanks for your advise I guess I'm gonna start looking for new engine might as well look for a supercharged one
  9. #9 Re: knocking
    May 2011
    El paso tx
    would if it be cheaper if i only fix the bearings or is not worth it?
  10. #10 Re: knocking
    I wouldnt.
    Unless you have a way to tune everything. You'll need a computer and tuner to make the engine work with the transmssion.
    Plus alot of other small thing.
    Swap is not as simple as it sounds.
    I'd just find another L26
  11. #11 Re: knocking
    Quote Originally Posted by crazybrownklick View Post
    You would need a whole rebuild, new crank, rod bearings, motor work have to be completely gone over to make things work, more money that its worth.
  12. #12 Re: knocking
    SE Level Member kc199's Avatar
    Nov 2011
    KCMO
    I had rod knock on mine as well...actually a broken connecting rod. A spun bearing will require machine work. Probably not worth it. Check car-part.com for a used engine. I just picked up a used 2006 engine with 103K for $350 from a local salvage business.
    1999 GT
  13. #13 Re: knocking
    Antioch, IL
    It would cost more to fix it. But you would need the crank polished smooth, rod cap too. Oversized bearing. Then the engine majorly flushed to get any tiny flakes out.
    My old car I spun a bearing (mazda3) dropped the pan replaced all rod bearings and drove it for thousands of miles until I let it get taken away. It still knocked so I couldnt go over 3k and I ran that lucas slick50 or w/e that thick slimy crap is.
    2009 Challenger SRT8
    Expert at being gay.
  14. #14 Re: knocking
    Quote Originally Posted by GMCustomerService View Post
    Louis
    GM Customer Service
    Louis, guess what?
    Doesn't matter.
    Anything from '95~ until 2009 works. Series II and III are virtually the same minus compression ratios.
    Quote Originally Posted by kc199 View Post
    This is the deal right here.
  15. #15 Re: knocking
    May 2011
    El paso tx
    is there anywhere I could get my computer tuned for the motor swap because they said they had here on a local junk yard a engine of a 2006 grand prix gt supercharged and they with 79k miles and 3 months of warranty would let it go for 450 I would only need the fuel rails. and I think it would be a big upgrade and yeah rebuilding my engine ain't worth it
  16. #16 Re: knocking
    you need the engine wire harness, and the pcm from that donor car/engine.
  17. #17 Re: knocking
    May 2011
    El paso tx
    is there a thread about swapping engines that would really help or is it easier to just to swap and engine?
  18. #18 Re: knocking
    May 2011
    El paso tx
    top swap I meant
  19. #19 Re: knocking
  20. #20 Re: knocking
    Not worth the hassle.
    Too much extra work to deal with.
  1. Knocking
    By gtpzmdc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2012, 11:30 PM
  2. 99 GTP Knocking
    By BoNeZ in forum General Tech Discussion
    Last Post: 10-28-2010, 05:52 PM
  3. Top End Knocking?
    By cerdman in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-01-2010, 08:18 PM
  4. why am i knocking?
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2010, 08:32 PM
  5. still knocking
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:19 PM
