Thread: Engine out...was hoping it was a cracked flex plate but it wasn't
Results 1 to 14 of 14
  1. #1 Engine out...was hoping it was a cracked flex plate but it wasn't
    SE Level Member kc199's Avatar
    Nov 2011
    KCMO
    Like the title says I finally got around to pulling the engine out of my GT. Was hoping that the knocking sound was just a cracked flex plate. But that wasn't the case. This is what I found in the oil pan
    [IMG][/IMG]
    Looks like I'm on the hunt for a replacement engine.
    I bought the car with the knock issue already so I don't know what conditions were when this happened. I didn't see any coolant in the oil when I drained it or in the pan. Anyone have any theories on what might have happened?
    1999 GT
  2. #2 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Nice job...seriously.. that's tought to do.
  3. #3 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Jacksonville, Fl
    !!! that is wicked! i never seen a cap busted like that haha. im currently purchasing a motor myself. mine had seized. i would suggest buying a good used motor. im picking mine on car-part.com. 55k for 1400. ive already considering buying a remanufactured motor but imo for the price, you cant beat a good used motor.
  4. #4 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Quote Originally Posted by kc199 View Post
    [IMG][/IMG]
    hey thats broken. lol like really broken....i bet a woman owned the car before you. oil light whats that mean?
  5. #5 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Jacksonville, Fl
    theory on what happened... whenever you opened your gas cap, you turned away just long enough for a gremlin to jump inside and hangout for awhile, tapping away on the inside of your motor until it finally gave out.
    but seriously... it may have just been a bad a/f ratio that was causing knock which was putting strain on the internals. which may have just been a vaccum leak. or maybe your cat was clogged. it could be a multitude of things.
  6. #6 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Houston
    WOW! Dont fret, thats why they put 6 of those in your engine. For backup, in case you break one or two.
  7. #7 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Quote Originally Posted by WOTFTW View Post
    my guess is it got a rod knock, then some one just floored it till it blew.
    i had a friend who had 78 t/a, had a 400 in it cam heads, intake and Nitrous. it got a rod knock, so he put the brick on the gas pedal, then reached in with a broom stick and hit the red button, it screamed bloody murder and grenaded. he took it all apart all the rods were bent, push rods looked like pretzels, and the cam broke into 3 pieces. heads took a beating as well, there went 4 grand real fast.
    Ohio
    Omg Scott.... Haha
  9. #9 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Wichita
    Wow that poor 38000.
    Have you checked out motors from LKQ or Morads? They're prices are reasonable. Or see if anyone on here has a spare they'd sell.
  10. #10 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Nov 2011
    KCMO
    I bought this cheap due to the knock and was hoping for a quick cheap fix. Really have to idea what happened but it was owned by a college student. His dad said that he had no idea what happened just started knocking. He went and got another GP and switched some parts with this one. Now I'm thinking there is more to the story. As I was pulling the engine out I was amazed at how easy a lot of the bolts and other things came out. Then I found a bolt missing from the transmission and a missing piece from the flywheel cover. I'm sure this engine isn't original to the car.
    Check out Dahmer Powertrain. They quoted me $1200 (plus core charge) for a reman 3800 with a 3 year unlimited mileage parts/labor warranty. That included delivery since I am local so not sure how much shipping would be to you. I found a 26K engine out of a 2006 for $475 so I will probably go that route.
    1999 GT
  11. #11 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Pennsylvania
    Quote Originally Posted by sdgtp99 View Post
    wow that poor 38000.
    moar liters!!!!!!
  12. #12 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    SE Level Member Cummins97's Avatar
    Sep 2011
    Missouri
    If you're willing to take a lil drive..... 3800 series 2 and transmission his last 4 are 4242
    Also, dont let him pull your leg and try to tell you he wont split them. He told me $300 for both or $200 each.
  13. #13 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Wichita
    Quote Originally Posted by SlowNA06 View Post
    moar liters!!!!!!
    Haha, I didn't even notice my typo! I say go for that low mileage 2006 motor.
  14. #14 Re: Engine out...was hoping it was a cracked flex plate but it wasn't
    Jacksonville, Fl
    i been looking for like 2 weeks now and cant find anything for that kind of price :/
    ill definitely look into dahmer and see what they got
  1. flex plate or engine issue
    By pontiacgtp98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-07-2012, 06:45 AM
  2. flex plate problems
    By butch2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2011, 07:08 PM
  3. Flex plate upgrade
    By rodman in forum Turbo
    Last Post: 12-12-2009, 12:25 AM
  4. flex plate
    By tihosick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 10:25 AM
