Little bit of both like when i can feel it building the power and then taking some time to put to the wheels so i guess more of the response. ya i have know idea on the tuning. we cleaned the throttle body like a couple of months ago and we did not clean it that well but well enough for this jerking problem we had to go away and the maf sensor cleaned as well. Later on i think we will clean it better and thoroughly.
What are the poly engine mounts? if its too much i think i rather just flip the mounts but if its cheap then ill get it, you got a like to em? Thanks for clearing that up now i know what your exactly talking about.I'd install poly upper engine mounts instead of bothering to flip the one... it still leaves tons of squish. The one you flip is the square mount inside the clamshell attached to the radiator support. The other upper engine mount is the round one inside the "dogbone."
But really, you need to clean your mass airflow sensor with mass airflow sensor cleaner and use throttlebody cleaner to clean your throttlebody. Remove the airbox and strap a 9" cone filter on the end of the mass airflow sensor tube.
And fresh stock spark plugs are nice if yours are near the end of their lifespan.
We will clean the MAF and throttle body again later when we get the leaks our car has of coolant and PS fluid and little bit of the oil now. that and i think we will get some new spark plugs for the car and wires for it too along with detailing the engine to give it a new engine look. Which Spark plugs and wires do you guys recommend and how hard are they to replace?
Thanks guys for the info too
