Thread: Stray ground wire?
Results 1 to 15 of 15
  1. #1 Stray ground wire?
    Dec 2011
    Reno, Nevada, United States
    Sorry, this seems unrelated to my misfire issue so I think I should start a new thread
    Down by coolant elbow, near the tension release for the belt I saw this wire sticking out of the harness (see pictures) I thought it was a broken/melted wire and I was looking for the other side but it doesn't exist, is this wire some sort of ground that has fallen off, or just a random stray wire?
    On my other thread user OH4CompG mentioned that it was a ground wire that's supposed to have been connected to the coil pack bracket, can anyone show me what this should look like so I can ground it again, or if it's not that ground offer advice on what it is, thanks
  2. #2 Re: Stray ground wire?
    Apr 2009
    Fort Worth TX
    Crimp a round connector on the end of it and attach it anywhere on the engine.
  3. #3 Re: Stray ground wire?
    You knew I had pics...right?
  4. #4 Re: Stray ground wire?
    Apr 2009
    Fort Worth TX
    Yea Bill, that about clears it up. Thanks
  5. #5 Re: Stray ground wire?
    On the 92-99 Bonnies it was on a bolt where that torx head is located
  6. #6 Re: Stray ground wire?
    Dec 2011
    thanks, everyone!
  7. #7 Re: Stray ground wire?
    Dec 2011
    Sorry, one last thing, any idea the size of nut I would need for that bolt, aren't most of the bolts metric in this vehicle?
    Ohio
    It's most likely an m10x1
  9. #9 Re: Stray ground wire?
    M10 x 1.50
    Say a 15mm head.. nearly any spare GM nut that looks like it..will work.
    GM's common ones
    M8 x 1.25
    M10 x 1.50
  10. #10 Re: Stray ground wire?
    Ohio
    this guy lol ^^
  11. #11 Re: Stray ground wire?
  12. #12 Re: Stray ground wire?
    Yoga city
    one ? i got a green wire runnign off my icm and coils. its cut goes no where.
  13. #13 Re: Stray ground wire?
  14. #14 Re: Stray ground wire?
    Apr 2009
    Fort Worth TX
    ^^^ALLDATA freak!
  15. #15 Re: Stray ground wire?
    GM ESI actually
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. Amp Ground
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 08:14 PM
  3. Bad Ground???
    By jjokrm in forum General Tech Discussion
    Last Post: 01-25-2009, 07:44 PM
  4. Stray Connector ???
    By DC1263 in forum General Tech Discussion
    Last Post: 12-28-2008, 10:02 PM
  5. Engine Ground to Chassis wire
    By AlmightyBirdman in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2008, 07:39 AM
