Ok, First I apologize if I have screwed up on the posting but it is my first one. 1998 Grand Prix GT 3.8k. I replaced the oil filter adapter gasket and I am concerned that I can not see oil flow in the valve cover after starting. Replaced gasket, added oil and filter, took the injector fuse out, cranked until oil light went out, replaced fuse and started. I only let it run for a little while before noticing the lack oil flow. Is this normal? Should I be able to see oil flow with the filler cap off?
