Thread: Engine Differences
Results 1 to 20 of 20
  1. #1 Engine Differences
    SE Level Member kc199's Avatar
    Nov 2011
    KCMO
    I know that I can replace my L36 engine with a newer L26 engine. What are the differences between the model years of L26 engines? Such as what is different on for example a 2004 and a 2007 or 2008?
    I have a 1999 Gt and found a low mileage 2006 L26 for a good price. Would this just be changing the UIM, LIM, fuel rails, and throttle body?
    1999 GT
  2. #2 Re: Engine Differences
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    the l36 is the older model
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  3. #3 Re: Engine Differences
    Nov 2011
    KCMO
    Quote Originally Posted by Austins01GP View Post
    Yeah, I guess I should have proof read it a little bit better. Wrote them backwards. Thanks...it's been edited.
    1999 GT
  4. #4 Re: Engine Differences
    You can swap the UIM, fuel rails, evap soleniod, tb and maybe the rear exhaust manifold.
  5. #5 Re: Engine Differences
    Nov 2010
    Maryville, MO
    ok sorry i was a bit confused! lol
    there are a few differences
    different fuel system (04+is returnless)
    LIM is metal instead of plastic
    they have electronic controlled throttle
    heads flow a little better
    im sure there is more thats just off the top of my head
    i believe you can do this swap, just takes a few modification
    // 2005 Comp G
  6. #6 Re: Engine Differences
    Nov 2011
    KCMO
    Will swictching the fuel rails and throttle body be enough. Or will there need to be additional mods?
    1999 GT
  7. #7 Re: Engine Differences
    ^^ you mean UIM not LIM.
  8. #8 Re: Engine Differences
    Nov 2010
    Maryville, MO
    yeah my fault! too use to the blower cars lol
    // 2005 Comp G
  9. #9 Re: Engine Differences
    I'm with ya! I have trouble with that black plastic thing on top too.
  10. #10 Re: Engine Differences
    Nov 2010
    Maryville, MO
    haha glad its not just me!
    and OP im not to familiar with this Bill might be able to add more than i, but i believe you need to keep the l36 fuel system when swap the motor out
    so instead of swithing you keep the l36 throttle body and fuel rails
    // 2005 Comp G
  11. #11 Re: Engine Differences
    Nov 2011
    KCMO
    That's what I was thinking. The L26 block should be the same and then just switch everything else from the L36.
    1999 GT
  12. #12 Re: Engine Differences
    Nov 2010
    Maryville, MO
    that would work blocks are the same
    , id keep the l26 heads and UIM tho
    they had some improvements
    // 2005 Comp G
  13. #13 Re: Engine Differences
    Nov 2011
    KCMO
    Heads would stay...but doesn't the UIM need to be changed over? Does anyone know if the exhaust will mate up?
    1999 GT
  14. #14 Re: Engine Differences
    You can use the UIM if....you get a TB adapter.
  15. #15 Re: Engine Differences
    Nov 2010
    Maryville, MO
    i confused myself lol
    i would use the newer heads and UIM they are better
    and i i think the exhaust will be fine
    // 2005 Comp G
  16. #16 Re: Engine Differences
    Nov 2011
    KCMO
    Thanks guys. Guess I was just second guessing myself. The only thing I will do different than what I had planned was the UIM. Looks like I need to place an order with ZZPerfomance.
    1999 GT
  17. #17 Re: Engine Differences
    When you use the UIM, you can use the L26 evap. It's an easy swap. Just hook up the hose from the tank to the evap soleniod and then the electrical connector.
    Sorry about spewing things out kinda randomly. Doing these too many times, you tend to leave out things that your hands did on their own w/o thinking about it. =0)
  18. #18 Re: Engine Differences
    Nov 2010
    Maryville, MO
    good luck!
    and im just north of kc with some various parts in my garage i could hook you up cheap if i have something you may need let me know
    // 2005 Comp G
  19. #19 Re: Engine Differences
    Nov 2011
    KCMO
    Thanks Austin, I appreciate you offering. What part of Missouri are you in? I'm from NWMO originally.
    1999 GT
  20. #20 Re: Engine Differences
    Nov 2010
    Maryville, MO
    st joseph
    goin to school at nwmsu right now in maryville
    // 2005 Comp G
  1. Differences between 05-08 GXP?
    By Walleyealx in forum General Tech Discussion
    Last Post: 10-18-2011, 02:53 AM
  2. L67/32 Alt Differences
    By footballplaya3k in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2011, 03:06 PM
  3. l36/l26 differences
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2011, 09:20 AM
  4. the differences
    By noom14921992 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2011, 04:00 PM
  5. GT/GTP MAF differences?
    By pontiackid in forum General Tech Discussion
    Last Post: 05-24-2009, 07:47 AM
