Thread: Electric Fan Not Working
Results 1 to 4 of 4
  1. #1 Electric Fan Not Working
    TN
    How warm does the temperature have to get before the electric fan will kick on? How does it work?
    I'm not sure mine is working, but I don't know. My car runs around 185-195 consistantly and it is fairly cool weather. I just flushed and filled it with coolant yesterday and was watching the temp and coolant level as i filled it and once it got to 200-205 and I noticed that the electric fans never kicked on.
    Is there a temperture sensitive switch somewhere that goes bad?
    What is the best/easiest way to check the fan out? I know I can test the fan motors easy enough by just running a hot wire to them, but what about them kicking on and off as needed? How do I check that?
  2. #2 Re: Electric Fan Not Working
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    fans wont come on until like 226 degrees...you can turn on the ac to see if they work, also there is a coolant temp sensor is what controls them....
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  3. #3 Re: Electric Fan Not Working
    214 and 226 IIRC
  4. #4 Re: Electric Fan Not Working
    TN
    I turned the A/C on and they came on, I think they are fine. My car just hasn't seen 214/226. Thanks guys
  1. Electric fans not working!
    By 02 Chevy in forum General Tech Discussion
    Last Post: 02-26-2012, 09:13 PM
  2. electric cut-out on the car
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:06 AM
