Thread: PLEASE HELP!!!Grand prix won't start when warm unless pumping the gas pedal..
Results 1 to 4 of 4
  1. #1 PLEASE HELP!!!Grand prix won't start when warm unless pumping the gas pedal..
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    So ever since I got my 2004 grand prix gt1 I have noticed that it won't start up when the engine is warm unless you pump the gas pedal when it turning the key. If you don't give it some gas it will start for a second and then just die. When it is colder out and the engine is cold it fires right up without any problems. Does anyone know what could be the problem? Thanks for all the help in advance!
  2. #2 Re: PLEASE HELP!!!Grand prix won't start when warm unless pumping the gas pedal..
    Ever cleaned the Throttle body?
    Or the MAF?
    I'd start there first
  3. #3 Re: PLEASE HELP!!!Grand prix won't start when warm unless pumping the gas pedal..
    Oct 2011
    huntley
    Do you have any write ups on how to do this?
  4. #4 Re: PLEASE HELP!!!Grand prix won't start when warm unless pumping the gas pedal..
    St. Louis
    Not really needed. Just remove the entire TB from the intake and spray the crap out of it w/ TB Cleaner, paying attention to the throttle plate. Then use MAF approved cleaner on the MAF, let it all dry and reassemble. Bet ya it'll fire right up after that. Do not spray TB cleaner while it is attached to the car. You don't want to fill your intake full of cleaner. Might want to clean the IAC too.
  1. why is my idle so low on cold start and sometimes fully warm?
    By 04silvercompg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2012, 02:49 PM
  2. 99' Grand Prix 3.8L stalling out when it gets warm
    By Michelleb76 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 04:28 PM
  3. diffucult warm start
    By Sowhatsup2000 in forum General Tech Discussion
    Last Post: 07-03-2010, 07:31 PM
  4. 2003 GT Won't Start when Engine is Warm...have to wait 45 min
    By LS2 GTO in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2009, 12:30 PM
  5. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
