Thread: Pulling Oil pan?
Results 1 to 8 of 8
  1. #1 Pulling Oil pan?
    SE Level Member woodoggie's Avatar
    KY
    '05, 3.8 naturally aspirated needs new main bearings.
    Can I, or has anyone ever pulled the oil pan with engine in the car?
    I was thinking about rolling new main bearings in without pulling the engine.
    But has anyone done it?
    Thanks,
  2. #2 Re: Pulling Oil pan?
    You can, but you have to drop the cradle.
  3. #3 Re: Pulling Oil pan?
    KY
    Have you done it before? 4 or 6 big bolts? reassembling problems?
  4. #4 Re: Pulling Oil pan?
    Ohio
    4 big 18mm head bolts on all four corners of the cradle
  5. #5 Re: Pulling Oil pan?
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Didn't you say in another thread that you drove the car, with bad main bearings, for 100+ miles???
    If that's the case, just replacing the bearings would be an absolute total waste of time. Just do what was suggested in your other thread, get a L36 short block. Problem solved.
    For all your 3800 needs:
  6. #6 Re: Pulling Oil pan?
    Yeah if the bearings were toast PRIOR, then the block would need to be machined and align bored so it wouldn't chuck another set in like an hour after starting it...if that.
  7. #7 Re: Pulling Oil pan?
    Jan 2009
    Tallahassee, FL
    Definitely just get a new shortblock. I pulled the pan on my car without dropping the cradle and it was the most pain in the a55 job I have ever done.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #8 Re: Pulling Oil pan?
    Being an 05 with the aluminum oil pan, it's quite easy and the cradle does not have to move at all.
    Jack and support the car
    Drain oil
    Remove oil level sensor on front of pan
    Pull pass tire and splash shield
    Remove two 15mm nuts from engine mount to subframe from under the car
    Jack engine from oil pan (use block of wood to keep from hurting pan, it's aluminum structural, not impervious to everything)
    Remove 3 15mm bolts holding mount bracket to the oil pan
    Wiggle mount out of place
    Remove 20 oil pan bolts and lower pan
    That's how you do it. I absolutely do not recommend putting bearings in a bad 3.8 unless it has been align bored and assembled by either a machine shop or someone with that same level of skill/machinery. These motors are quite finicky about how they are put together.
  1. Pulling a knocking 3.8.
    By WOLF257 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2012, 03:35 PM
  2. pulling the motor?
    By MrPhotographer06 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2011, 05:32 AM
  3. pulling under WOT
    By JESSEGOTTA GP GT in forum Brakes/Suspension/Chassis
    Last Post: 09-01-2011, 08:22 AM
  4. Pulling the AC
    By protoplayer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2011, 09:53 AM
  5. FWI without pulling the bumper.
    By JoshMcMadMac in forum General Tech Discussion
    Last Post: 05-14-2008, 08:35 AM
