Thread: Engine Rattle under load
Results 1 to 11 of 11
  1. #1 Re: Engine Rattle under load
    St. Louis
    Junkyard manifold and crossover pipe? Either that or remove the loose bolt that won't tighten, get a smaller diameter bolt in there and put a nut on the other side and tighten it down. It would work for now. Might want to throw a lock washer in there as well so it doesn't vibrate loose again.
  2. #2 Re: Engine Rattle under load
    GT Level Member ShadowSwept's Avatar
    Kentucky
    Thanks! Would you say that's the likely culprit for the horsepower loss, or would that be fuel related (seems to pulse like the idle)?
  1. engine rattle
    By stok3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2011, 07:47 PM
  2. Engine Rattle
    By setshot50 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2011, 08:41 PM
  3. Engine tapping noise under load and cold only
    By mojonba in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2011, 09:07 PM
  4. having troubles with load on engine
    By tonydtech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-10-2009, 03:44 PM
  5. engine can't handle load...
    Last Post: 05-02-2009, 02:51 PM
