Hello all,
I'm a new member here from Central Texas, just posted a hello and some pics in the intro section.
My wife has a really sharp 2001 GP GT with the Special Edition package. It's got 150K miles, and has been a great car, but just recently developed an odd problem. 95% of the time, the first time you turn the key to start the car, it will start and then stall right out. You turn the key again and it starts right up and runs like a watch.
There are no codes. No CE light. I'm stumped. Other than this issue, the car runs and drivers perfect. So far I've done a full tune-up, including Delco plugs, wires, air and fuel filter, pcv valve, and had the fuel system cleaned/flushed at a shop. I also replaced the EGR valve, after a friend suggested that "might" be it.
I'm not sure how this could be related, but I recently did a lot of other work and had the car somewhat torn apart, and this cropped up soon after. I had a bad oil pan leak, and replacing the pan gasket was a PAIN, and also the power steering pump, one line, and the entire rack were replaced, along with both front CV axles (I know, it was overkill, but once I got started I kept going).
Anyway other than the weird start-stall-start again and then run fine issue, the car is a champ. Would really like to sort this out. Any ideas are appreciated!
-Mike
