Thread: 2001 Grand Prix GT starts then stalls then starts up and is fine???
Results 1 to 13 of 13
  1. #1 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Jan 2012
    Round Rock Texas
    Hello all,
    I'm a new member here from Central Texas, just posted a hello and some pics in the intro section.
    My wife has a really sharp 2001 GP GT with the Special Edition package. It's got 150K miles, and has been a great car, but just recently developed an odd problem. 95% of the time, the first time you turn the key to start the car, it will start and then stall right out. You turn the key again and it starts right up and runs like a watch.
    There are no codes. No CE light. I'm stumped. Other than this issue, the car runs and drivers perfect. So far I've done a full tune-up, including Delco plugs, wires, air and fuel filter, pcv valve, and had the fuel system cleaned/flushed at a shop. I also replaced the EGR valve, after a friend suggested that "might" be it.
    I'm not sure how this could be related, but I recently did a lot of other work and had the car somewhat torn apart, and this cropped up soon after. I had a bad oil pan leak, and replacing the pan gasket was a PAIN, and also the power steering pump, one line, and the entire rack were replaced, along with both front CV axles (I know, it was overkill, but once I got started I kept going).
    Anyway other than the weird start-stall-start again and then run fine issue, the car is a champ. Would really like to sort this out. Any ideas are appreciated!
    -Mike
  2. #2 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    St. Louis
    Sharp looking SE. I like it!
    Cleaned the MAF on it recently?
    Try this and tell me if it starts any better or same. Turn the key to "on" and let the fuel pump prime. Then turn the key off and back to on again and let it prime again, then try and start it.
  3. #3 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Have you pulled the vac line off the FPR ever?
    If fuel comes out, then that is your issue.
    And cleaning your MAF couldnt hurt either.
  4. #4 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Jan 2012
    Round Rock Texas
    Quote Originally Posted by FordMan77 View Post
    No I've not cleaned that. It's just the unit between the air filter box and the intake, correct? How do you clean it? Just take it off and wipe it out, or do you use carb cleaner or something?
    Glad you the car, and thanks for the advice!
    -Mike
  5. #5 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Jan 2012
    Round Rock Texas
    Sorry to sound stupid, but what is the FPR.....fuel pump regulator? Is it on the fuel rails on top of the intake? If I pull the line and fuel comes out, do I just need to order a new FPR....?
    Thanks again for the reply.
    -Mike
  6. #6 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    St. Louis
    The MAF is the black sensor that is in the top of the TB. You will need a safety torx bit to remove it. Once out, use approved MAF cleaner (avail. at all autoparts stores). Do not use carb or TB cleaner as it could damage it. Also, just spray the small wires inside the MAF, don't touch them with anything to clean them. Then just let it dry 100% before you reinstall it.
    The FPR is the Fuel Pressure Regulator. And yes, it's on the fuel rail in the front towards the left side (drivers) of the motor. Yes, if fuel comes out then just buy a new regualtor.
  7. #7 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Pennsylvania
    don't forget to use throttlebody cleaner on the throttlebody if the plate is black instead of shiny brass.
  8. #8 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Dec 2011
    Roanoke, IL
    not to jack your thread, but i have the same problem. but instead of starting and running the second time, it dies every time. it will stay running if i give it a little gas. am i looking at the same problem?
    2005 Grand Prix- Enkiel LF-10 Rims/Dunlop Tires, Home brewed CAI, Gutted Cat/No Res/Dynomax VT muffler, 2 12'' Kicker Solo-Baris L7s, 600.1 Kicker Amp
    Apr 2008
    Try all the simple stuff first and if that don't work replace the crankshaft position sensor that was the problem with mine.
    Sent from my LG-P925 using Tapatalk
  10. #10 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Quote Originally Posted by sk8erdude View Post
    Try unplugging the MAF and then start the car and see if it will run.
  11. #11 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Jan 2012
    Round Rock Texas
    Thanks very much for all the tips and ideas.....and clarifications. WIll play with it and see what happens!
    -Mike
  12. #12 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    SE Level Member grandprix85's Avatar
    Milwaukee, WI
    keep us posted on what the problem was. Im having the same issue that the original poster has with my 02 Grand Prix GT
    02 GP GT stock with tinted windows, 140K
  13. #13 Re: 2001 Grand Prix GT starts then stalls then starts up and is fine???
    Milwaukee, WI
    well it turned out that i needed a fuel pressure regulator. So if u recently changed the spark plugs, pcv valve, fuel filter and did a fuel system cleaning like i did and if u was still having the start then stall then start again and runs fine problem with no check engine light on, then u should check out the fuel pressure regulator
  1. starts/ dies x10 then is fine
    By ItHurtz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 02:19 AM
  2. Car starts, but stalls
    By maverickdog8 in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-06-2011, 03:35 PM
  3. 00 GT Starts then stalls?
    By dynamicyaz in forum Introductions/Noob Questions
    Last Post: 04-13-2010, 03:08 PM
  4. Car Starts and Stalls
    By 1000PRIX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 09:40 PM
  5. grand prix starts, will not idle, stalls.
    By ibanez0110 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2009, 01:20 PM
