Thread: Dies when its in park
Results 1 to 6 of 6
  1. #1 Dies when its in park
    May 2011
    ohio
    sometimes my car will die when its only in park but if i quitly put it in reverse or drive it will not die on me. It mainly does it when its heated up.
    any ideas what this could be.
    also seems to be happening more since i got my dp installed
  2. #2 Re: Dies when its in park
    St. Louis
    Try cleaning the MAF. Then, if it still happens try changing the IAC.
    Also, post up the year and mileage as that may help us help you. The 04+ cars are known to build up junk on the TB and cause this issue as well.
  3. #3 Re: Dies when its in park
    Kansas
  4. #4 Re: Dies when its in park
    Pennsylvania
    03 gt 70k miles, CAI box and downpipe, correct?
    Scan for codes. All auto parts stores do this for free.
    Check for a vacuum leak. Spray carb cleaner around vacuum hoses and gaskets while running. Increased rpms will indicate leak.
    Clean throttlebody
    Clean mass airflow sensor - especially if you have an oiled intake filter, like K&N.
    If your intake filter is clogged, clean it.
    Make sure you didn't remove the throttlebody screen when you installed your air filter.
  5. #5 Re: Dies when its in park
    Pennsylvania
    Right concept, wrong car.
  6. #6 Re: Dies when its in park
    May 2011
    ohio
    thanks guys. ill do that and get back and see if that works
  1. Cant Get Car Out Of Park
    By OnERHOuR in forum General Tech Discussion
    Last Post: 09-25-2011, 02:46 PM
  2. Park to reverse
    By shawnschuldt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2010, 12:14 AM
  3. Can't get key out after putting car in park.
    By Dusty02se in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-11-2010, 02:44 PM
  4. Where do you park.....
    By SiDeWaYz in forum Off Topic Discussion
    Last Post: 06-13-2010, 09:34 AM
  5. wipers that won't park
    By flyboyray1 in forum General Tech Discussion
    Last Post: 01-21-2010, 01:53 PM
