Thread: Another dash light!! UGGH!
Results 1 to 4 of 4
  1. #1 Another dash light!! UGGH!
    GTP Level Member
    springfield IL
    Ok last week i changed my oil and filter. Few days later i noticed my oil light is on..??!! I pulled over checked to see if it was leaking, nothing... Checked the dip stick... Full. Only thing i noticed was the oil was past the full mark on the dip stick.
    Could adding a lil to much oil be the cause of the oil light coming on..??!
    I check it every day for leaks or any other signs and found NOTHING!
  2. #2 Re: Another dash light!! UGGH!
    the LOW oil light?
    Could be a bad sensor.
  3. #3 Re: Another dash light!! UGGH!
    St. Louis
    Check the 2 wires that connect to the oil level sensor. This is the sensor located in the side of the pan facing the radiator. Has a large nylon nut on it and a small harness attached to it. Mine did this once and I found one of the wires to be loose. Cleaned it up and made sure they were tight and all is well.
  4. #4 Re: Another dash light!! UGGH!
    GTP Level Member
    springfield IL
    This past weekend i noticed the oil light hasnt came on...??Im guessing its cause i put a lil too much in..???!!?? LolEverything is fine so...
  1. is this normal...dash light dim out few second at start up?
    By nemesis in forum General Tech Discussion
    Last Post: 06-06-2012, 06:11 AM
  2. Certain light out in dash?
    By Godfather in forum Visual/Body Modifications
    Last Post: 07-20-2011, 01:34 PM
  3. Dash dummy light help
    By 04gp05g610g8gxp in forum General Tech Discussion
    Last Post: 01-31-2011, 03:14 PM
  4. brake light on dash
    By quadracer960 in forum General Tech Discussion
    Last Post: 03-28-2010, 11:14 PM
  5. parking brake light on dash
    By Jcal1120 in forum Brakes/Suspension/Chassis
    Last Post: 09-19-2009, 08:16 PM
