I got it installed finally!!! Got a pcv coupler and a pipe and hooked them together to fit the MAF and the pipe thing came with a small third hole and a little u bend pipe to connect the stupid hose for the stupid cali emissions and connected the other side to the filter. now the filter touches a little part of the roof and is at the back behind the headlight that has a hole there. we used zip tie to hold it still and up on the bar there and zip tied the pcm down too. it now makes a rumble noise now that sounds cool like a muscle car sound, is that good?
EDIT: the zip tie there that is clamping the maf to the pipe there is gone and we put acutal clamps there since it came off when we looked at when we came back from driving. so now it should be stuck on good (we use the same clamp thats clamping the filter there the silver one).
