Thread: Coolent temp Goes to regular temp and drops down?
Results 1 to 9 of 9
  1. #1 Coolent temp Goes to regular temp and drops down?
    Jan 2012
    mn
    I just did the lower and upper intake gaskets on a 2000 grand prix and flushed the antifreeze out and now it does not run hot, it goes up to the first bigger line on the temp guage which on my other grand prix is normal temp but on this other one it drops back down. The car never gets hot just goes up to the first line and goes back down any ideas there? Thanks
  2. #2 Re: Coolent temp Goes to regular temp and drops down?
    I'm reading you saying ...it goes up then goes down. How far, what temps are those marks. Not being a jerk...trying to get enough info to understand how low etc it's dropping.
  3. #3 Re: Coolent temp Goes to regular temp and drops down?
    St. Louis
    Sounds like you need to bleed the cooling system. There's air in it from what you describe, barring any wierd temps that Bill is asking for.
    Jan 2009
    Tallahassee, FL
    If there was air in the system then it would be running hot
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  5. #5 Re: Coolent temp Goes to regular temp and drops down?
    Jan 2012
    FT Campbell, KY
    Air in the system would make the car get REALLY hot, then very suddenly get pretty cool. Like a temperature swing from 235-190 all at once. My L36 Camaro did that to me a few times.
    Colleen
    : CAI, HV3, 2.5" d/p w/h/f cat. Full suspension, PowerSlots w/Hawk HPS, GR2s, Sonar projectors. Needs tune. Awaiting install of FBod brakes.
    Shianne: 98 L36 MM5. Good start to a LONG project.
    Jan 2009
    Tallahassee, FL
    Since he's saying the first line on the temp gauge I don't think that he's overheating
    77 Morris Garage B
  7. #7 Re: Coolent temp Goes to regular temp and drops down?
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    Is your motor the 3100?
    Sounds like major air in your system or your thermostat is broke open.
    I'd replace the thermostat and gasket since they are cheap, then bleed the car the old school way jacked up with the rad cap off.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  8. #8 Re: Coolent temp Goes to regular temp and drops down?
    Jan 2012
    mn
    The temp goes up to the first bigger line then drops back down to the middle of 160 and that bigger line. Does that back and forth. I already replaced the stat with a good one. I have just never seen this before. Maybe a bad stat?
  9. #9 Re: Coolent temp Goes to regular temp and drops down?
    BTW guys..our coolant sensors suck at reading air temps of the LIM. So if you don't have enough coolant to cover the sensor..it can read cool while overheating from lack of coolant.
    It sounds like you have some air in the sytem, you should bleed it
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. trans temp
    By stishdr in forum General Tech Discussion
    Last Post: 07-31-2011, 09:31 AM
  3. Is my temp okay?
    By tracker1925 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 07:52 AM
  4. Operating Temp????
    By reaper55 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2010, 08:56 PM
  5. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
