Thread: Engine "Knock"
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Engine "Knock"
    St. Louis
    Good thought, used that trick in an old 302 for a while to quiet the lifters.
    Lucas oil additive may help, but I have a bad feeling that we're seeing the beginning of rod knock.
  2. #22 Re: Engine "Knock"
    Lucas Stop Tick is about the same vicosity as Gear Lube...it's thick sh1t.
    You'll know really quick if it is top or bottom end related, as bottom end related stuff really won't quiet down that much.
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. Recall 07035 engine fire "warning"
    By chuckd98gtp in forum The Rant Forum
    Last Post: 07-06-2011, 01:35 PM
  3. Guess I have a "knock monster"
    By mkyota1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-29-2011, 11:26 PM
  4. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
  5. What does "Knock" Feel like
    By xsvtank in forum General Tech Discussion
    Last Post: 09-10-2010, 05:18 PM
