Thread: Spun bearings after mechanic replaced head gaskets, UIM and LIM
Results 1 to 17 of 17
  1. #1 Re: Spun bearings after mechanic replaced head gaskets, UIM and LIM
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    i bet they didnt change the oil after doing the job.
    I don't like that it happened, I'm just agreeing
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  2. #2 Re: Spun bearings after mechanic replaced head gaskets, UIM and LIM
    Tucson, AZ
    Sorry, I forgot to mention I drained the oil before I took it to them.
  3. #3 Re: Spun bearings after mechanic replaced head gaskets, UIM and LIM
    yes, but when taking those parts off, coolant is still covering the valley and down on to the rods and crank.
    What sould have been done was drain the oil, fix the car, fill with oil, run for a few miles and drain again, that way all the coolant is out.
  4. #4 Re: Spun bearings after mechanic replaced head gaskets, UIM and LIM
    Tucson, AZ
    Very true. I should have thought things through a little more when they called me to get the car because it was "done," and I ended up waiting 3 hours when I got there-- and helping them-- while they actually finished it up.
    I have never gone to a mechanic before, but isn't it normal for payment to be remitted once the work is complete? They kept asking for payments while they had it, and I actually made $300 in payments along the way so they "could pay their tech." Finally, I told them I'd prefer to make the final payment once the car is done.
    The night I picked it up, I wasn't sure I was going to have transportation to pick it up, but they told me payment needed to be made that night, whether I pick it up or not.
    Is this normal? Seemed a bit strange to me, but then again I've never used a mechanic before.
  5. #5 Re: Spun bearings after mechanic replaced head gaskets, UIM and LIM
    Quote Originally Posted by fju2 View Post
    100% not normal.
    In response to the above post, if they ran it without oil, its shot.
    Best bet is a used motor, change the LIM gaskets and leave it at that.
  6. #6 Re: Spun bearings after mechanic replaced head gaskets, UIM and LIM
    Tucson, AZ
    And to add salt in the wound, I sold it on Thursday while it was not showing any signs of problems, got a call from the guy about 2 later, saying there was a problem with the car. I went to check it out, replaced the alternator and battery, fired it up and test drove it, engine died 30 seconds later, and wouldn't turn over again. I towed it home, gave the guy his money back and here I am trying to recoup my losses.
  7. #7 Re: Spun bearings after mechanic replaced head gaskets, UIM and LIM
    take it back to the shop, its their fault if they didnt do the job right.
  1. replaced LIM and UIM gaskets, new elbow leaking
    By holorinhal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2011, 06:01 AM
  2. Spun bearing (#1) replaced all 6 still knocking! WTF?
    By datafive0 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2011, 07:52 AM
  3. $$$$$$ 4 Head gaskets
    By Octane in forum Engine
    Last Post: 01-06-2011, 12:54 AM
  4. Are L36 and L67 head gaskets the same?
    By TDCRacing in forum General Tech Discussion
    Last Post: 03-12-2009, 01:09 AM
  5. Head Gaskets...
    By newfie in forum Turbo
    Last Post: 01-18-2008, 12:31 AM
