Thread: NIC Cam
Results 1 to 14 of 14
  1. #1 NIC Cam
    SE Level Member RedGrandprixgt53's Avatar
    Oct 2011
    Kenosha, WI
    So Im thinking about getting a NIC cam from zzp. I was wondering if I needed the upgraded springs, retainers, rollmaster double roller, and the comp OE-R lifters. Or would I be fine without it. Im going to top swap in the near future.
  2. #2 Re: NIC Cam
  3. #3 Re: NIC Cam
    Oct 2011
    Kenosha, WI
    okay thanks that helps a lot. saves about 400 extra bucks.
  4. #4 Re: NIC Cam
    Florida
    so what benifit does the NIC have over other cams. i read on ZZP that it is a difficult cam to tune. but that it can make great power with minor mods.
  5. #5 Re: NIC Cam
    its difficult to tune if you dont use a wideband. the reason it makes 'great power' is because of the large amount of overlap (both valves open at the same time) so it bleeds boost. this allows you to run smaller pulleys than normal.
  6. #6 Re: NIC Cam
    Oct 2011
    Kenosha, WI
    I like the lopey idle it has and I would have someone tune it for me
  7. #7 Re: NIC Cam
    Oct 2011
    Kenosha, WI
    and if it bleeds boost is that bad?
  8. #8 Re: NIC Cam
    GT Level Member gpgt04's Avatar
    MA
    no boost out of his gt though. or is this in the wrong section?
  9. #9 Re: NIC Cam
    what car are you contemplating putting this in? this will be a BAD cam for an n/a car.
  10. #10 Re: NIC Cam
    Omaha, NE
    He's topswapping, so it's assumed he would install the cam at that time.
  11. #11 Re: NIC Cam
  12. #12 Re: NIC Cam
    Oct 2011
    Kenosha, WI
    yeah around the same time, might have the cam in a little before the top swap though. depends.
  13. #13 Re: NIC Cam
    Omaha, NE
    Hold off on the cam, do it all while you already have it apart. As said before, you don't want to put that cam in without a supercharger or it'll be bad news for your motor.
  14. #14 Re: NIC Cam
    Oct 2011
    Kenosha, WI
    ill just wait to install everything. thanks for the info
cam, nic
