Thread: Will an L26 swap into an L36 car?
Results 1 to 6 of 6
  1. #1 Will an L26 swap into an L36 car?
    SE Level Member ls1freek's Avatar
    Sublette, Ks
    My mom has an 02 Bonneville with the NA 3.8 and the car recently spun a main bearing, she came across a wrecked 05 Bonneville with 25k miles and good drivetrain for $500! I'm wondering if the block/heads assembly would be a direct swap or not, also the trans too. Any info would be greatly appreciated. Thanks!
    2005 Grand Prix GTP w/CompG
    - Stock
  2. #2 Re: Will an L26 swap into an L36 car?
    Portland Oregon
    The trans is wired differently. If you use your external range selector switch it's usable but I don't know what else need be done. I think you have to have 03 trans tables loaded.
    As for the engine. If you want it easy, you'll have to swap the LIM and UIM to the style that's on your old motor. You could get a gen V to l67 adapter plate and run the aluminum UIM but then you have to worry about other things like the evap being different and such.
  3. #3 Re: Will an L26 swap into an L36 car?
    Sublette, Ks
    This I'm sure is a dumb question, but what does LIM and UIM stand for?
    - Stock
  4. #4 Re: Will an L26 swap into an L36 car?
    The Boss Iceman6669's Avatar
    Jun 2011
    LIM = Lower Intake Manifold
    UIM = Upper Intake Manifold
    2011 F-150 Yote powered
  5. #5 Re: Will an L26 swap into an L36 car?
    Sublette, Ks
    Ok, yeah we were planning on re-using the current intake mani, but along the lines of sensors and stuff, the block is the same? Including crank sensor teeth, cam sensor location, etc.?
    - Stock
  6. #6 Re: Will an L26 swap into an L36 car?
    Portland Oregon
    Yeah, you won't have to worry about anything else. Just swap the upper and lower intakes.
  1. gt gtp swap
    By danross in forum General Tech Discussion
    Last Post: 05-28-2013, 11:56 AM
  2. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
  3. 97 DIC swap ?'s
    By X97prixX in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2009, 01:35 PM
  4. top swap
    By jrgoleman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-22-2009, 04:24 PM
