Thread: What is the name of the plastic piece on the very tip of the injector? (pic inside)
Results 1 to 6 of 6
  1. #1 Re: What is the name of the plastic piece on the very tip of the injector? (pic insid
    If you are talking about the piece that holds the o-ring on, it's unnecessary. It's only there to hold the ring. And the rings will hold on to install w/o worries, will sit on the head when you remove. They won't go into the head as they are larger than the injector hole.
  2. #2 Re: What is the name of the plastic piece on the very tip of the injector? (pic insid
    Keller,TX
    X3...But I believe its called the pintle cap.
  3. #3 Re: What is the name of the plastic piece on the very tip of the injector? (pic insid
    Tucson, AZ
    It appears as if the O-ring is seated on the piece; so it's fine if it's seated directly on the injector?
  1. Intercooler fill plastic piece
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2011, 06:19 AM
  2. need help finding location for black plastic piece!
    By mkedwards in forum General Tech Discussion
    Last Post: 04-13-2011, 10:43 AM
  3. Plastic piece/clip below key switch interior?
    By frtaylor9 in forum 04+ Specifics
    Last Post: 03-15-2011, 06:31 PM
  4. Replies: 28
    Last Post: 04-27-2010, 05:45 PM
  5. how do you take this black plastic piece out?
    By nemesis in forum General Tech Discussion
    Last Post: 04-25-2008, 06:21 PM
